Defender Vs Series Track Rod ends
Not sure about the thread, think they are the same BUT, from memory, I think the taper is different so you need to make sure the TRE matches the component it's being mated to or it will only contact on a small part of the taper.
The only difference is the length of the thread where it bolts through the steering arm. The series ones are shorter. You can use a defender tre on a series, but series ones on a defender are a bit short and you can barely get the thread through the nyloc. Defender steering arms are thicker than series.
the taper is the same, and the thread that goes into the rods is the same.
  • Like 1
