bongo321 Posted November 2, 2018 Share Posted November 2, 2018 Hi can anyone tell me how to wire spots when using a boomslang loom kit . I also have a plug n play spotlight kit , can I use both together , can I use the vehicle o/s headlight plug that's made redundant using the Boomslang , Or just wire spots from scratch if so How please . Gerry Quote Link to comment Share on other sites More sharing options...
crwoody Posted November 2, 2018 Share Posted November 2, 2018 You would be alright to use the redundant O/S plug so long as it will only be used to trigger a relay, the relay then feeds the spots from a more substantial supply in the same way that the Boomslang relays do. Quote Link to comment Share on other sites More sharing options...
bongo321 Posted November 2, 2018 Author Share Posted November 2, 2018 (edited) Thanks for that , its a relief . Made my night lol . Yes would be just to get the spots to work on full beam with a switch to isolate as normally done . So if I take the high beam of the reduntant to the relay , power the relay from the battery , relay wired to spots , and earth all . Is that it . Unless you know the relay numbers for each . Think my relay is 4 pin , But see some are 5 , Can I switch the relay if its only 4 pins . Again thanks for letting me know I can use the redundant. Edited November 2, 2018 by bongo321 Quote Link to comment Share on other sites More sharing options...
western Posted November 2, 2018 Share Posted November 2, 2018 just wire with a 4 pin relay, so new extra lights come on with main/full beam & extinguish when dip beam is selected, that's how mine are wired, no need to a extra switch or warning light as the main beam blue warning light takes care of that job. have a read of Quote Link to comment Share on other sites More sharing options...
bongo321 Posted November 2, 2018 Author Share Posted November 2, 2018 (edited) Hi Its only so i can isolate the spots , so only on with full beam When i want them on . Sorry I see it now , its the override switch . Edited November 2, 2018 by bongo321 Quote Link to comment Share on other sites More sharing options...
bongo321 Posted November 3, 2018 Author Share Posted November 3, 2018 (edited) Sorry im a bit of a dunce especially since this cancer rubbish i question myself on everything , before i would just of done it . So please have patience with me , Am i right here , i take a wire from the reduntant hi beam plug , via a override switch then to 85 on the relay and wire the relay direct to battery live/earth and live to spots and ok to earth spots to frame . Relay 86 earth (all) 87 live to spots , 30 live from Batt , 85 from redundent plug hi beam via isolator switch to relay . Edited November 3, 2018 by bongo321 1 Quote Link to comment Share on other sites More sharing options...
western Posted November 3, 2018 Share Posted November 3, 2018 wire as shown in the first diagram of the link. main beam wire is blue/white trace. use that to tigger the relay, which also needs a ignition controlled 12v feed to allow the relay coil to work. my front driving lights relay is earthed to the wing edge, both lights are earthed o the front bumper, haven't had any problems since fitting about 20 years ago. Quote Link to comment Share on other sites More sharing options...
