P38 Paul Posted September 26, 2019 Author Share Posted September 26, 2019 9 hours ago, Escape said: Paul, Snagger is right, if you have both wheels of an axle off the ground, you should be able to turn them through the open diff. They will of course spin in oposite directions and some resistance will be felt, but not too much. You should certainly be able to spin a wheel fast enough to check for sticking brakes, bearings etc. Filip Thanks for that Filip , will have a go on Saturday when I get home , hope Snagger isn't right with it being seized 😟 Quote Link to comment Share on other sites More sharing options...
Snagger Posted September 27, 2019 Share Posted September 27, 2019 11 hours ago, P38 Paul said: Thanks for that Filip , will have a go on Saturday when I get home , hope Snagger isn't right with it being seized 😟 If it’s just a wheel bearing, then at least it won’t be outrageously expensive and you’ll have a cause that you can end the problem. But I too hope that it’s nothing severe or expensive. Quote Link to comment Share on other sites More sharing options...
