Bench top milling machine
Stellaghost
It's the variable speed gizmo that's tripping electrics if I connect motor to house plug it starts no problem but runs too quickly and just wants to trash cutters have had sparks from work check it out but no joy rtd's are too sensitive mill came from an older property and ran fine on his electrics goes ok with genny though thanks
That's a nice size!
Assuming your using a 1ph to 3ph inverter;
For mine you have to wire the motor in Delta for 220v not Star for 415v, easy on a dual voltage motor but I don't know what your is.
Do you have a b type rcd? If so try a C or D they will be 'slower blow'.  I would do it as a second circuit though as you might not want the whole ring to be slow blow.
Or as said above you can change the ramp up and down, mine faults if i ask it to do things too slowly for some reason?
