KEITHB252 Posted November 9, 2018 Share Posted November 9, 2018 The passenger seat on my TD4 is not heating up,any idea what the fault could be please or where should i look for starters. Thank You Quote Link to comment Share on other sites More sharing options...
Wicklow Landie Posted November 10, 2018 Share Posted November 10, 2018 Hi, check that you have power coming to the connector under the seat then if you have 12volts there, then it’s the heating pad in the seat itself. It can be replaced but they are expensive and you have to be brave in tearing down the seat coverings to access the pad. The pad is a most common fault Good luck. Quote Link to comment Share on other sites More sharing options...
KEITHB252 Posted November 11, 2018 Author Share Posted November 11, 2018 Thank you. Quote Link to comment Share on other sites More sharing options...
