Tim2809 Posted November 11, 2018 Share Posted November 11, 2018 i bought a set of original heated seats for my 110 all foams good and firm so got on and fitted them. put power to them and nothing.got multi meter out on resistance and base cusions appear to have no continuity does anyone know a part number for the base element or do i have to buy a complete kit. all the ones ive seen have 2 settings where the genuine has 1 and i have got carling switches in a mud dash so dont want to swap switches if possible. Quote Link to comment Share on other sites More sharing options...
Scotts90 Posted November 11, 2018 Share Posted November 11, 2018 Do the backs heat or have you nothing at all? Quote Link to comment Share on other sites More sharing options...
Steve King Posted November 11, 2018 Share Posted November 11, 2018 Land Rover replacement pads are hideously expensive - try Exmoor Trim. Don' t think they sell part sets though, probably still cheaer though! Quote Link to comment Share on other sites More sharing options...
Eightpot Posted November 12, 2018 Share Posted November 12, 2018 The wire terminations on the heater pad can come loose with age - not too difficult to resolver. Otherwise the waeco seat kits are great. Quote Link to comment Share on other sites More sharing options...
Tim2809 Posted November 12, 2018 Author Share Posted November 12, 2018 17 hours ago, Scotts90 said: Do the backs heat or have you nothing at all? they are wired in series so backs dont work but i have continuity through them. 2 hours ago, Eightpot said: The wire terminations on the heater pad can come loose with age - not too difficult to resolver. Otherwise the waeco seat kits are great. have been in touch with exmoor and base elements are £38 each so will try the repair if not will think about a new kit. the waeco seats have 2 heat settings but my switches are carling single stage switches so may end up with just low setting Quote Link to comment Share on other sites More sharing options...
Scotts90 Posted November 12, 2018 Share Posted November 12, 2018 I had to solder in a new thermo switch on my OE heated seat element. Hardest part was gently peeling the element from the foam as it was glued on. Switch was only a couple of quid from an electronics supplier. Quote Link to comment Share on other sites More sharing options...
Tim2809 Posted November 12, 2018 Author Share Posted November 12, 2018 1 hour ago, Scotts90 said: I had to solder in a new thermo switch on my OE heated seat element. Hardest part was gently peeling the element from the foam as it was glued on. Switch was only a couple of quid from an electronics supplier. im going to pull them apart this week and have a look. any idea of supplier or will it become apparent once apart Quote Link to comment Share on other sites More sharing options...
Scotts90 Posted November 12, 2018 Share Posted November 12, 2018 This little blighter here... I purchased two as they were so expensive http://sinolec.co.uk/en/normally-closed-thermostats-loose-bracket/399-thermostat-50-closed.html Quote Link to comment Share on other sites More sharing options...
Tim2809 Posted November 12, 2018 Author Share Posted November 12, 2018 27 minutes ago, Scotts90 said: This little blighter here... I purchased two as they were so expensive http://sinolec.co.uk/en/normally-closed-thermostats-loose-bracket/399-thermostat-50-closed.html ouch. lol. hopefully thats the issue. i presume these are in the base and not the backrests Quote Link to comment Share on other sites More sharing options...
Scotts90 Posted November 12, 2018 Share Posted November 12, 2018 Nope, in the lumbar area on the backrest Quote Link to comment Share on other sites More sharing options...
Tim2809 Posted November 12, 2018 Author Share Posted November 12, 2018 i have continuity through the back rests. hopefully may be a broken cable instead in the base. just another issue to sort Quote Link to comment Share on other sites More sharing options...
Tim2809 Posted November 13, 2018 Author Share Posted November 13, 2018 took apart and elements have fallen apart. have emailed exmoor trim Quote Link to comment Share on other sites More sharing options...
landroversforever Posted November 13, 2018 Share Posted November 13, 2018 I've got a Waeco set waiting to go in mine and they look like good quality Quote Link to comment Share on other sites More sharing options...
Tim2809 Posted November 14, 2018 Author Share Posted November 14, 2018 22 hours ago, landroversforever said: I've got a Waeco set waiting to go in mine and they look like good quality did see them and wondered if can re wire just to use either the high or low as dont want to change switches unless i have too Quote Link to comment Share on other sites More sharing options...
landroversforever Posted November 14, 2018 Share Posted November 14, 2018 I can grab a picture of the switch wiring on them if you like? They're just a little 3 position job, Low-Off-High from memory, rather than off-low-high Quote Link to comment Share on other sites More sharing options...
Eightpot Posted November 14, 2018 Share Posted November 14, 2018 Waco do two different kits - there's a normal element type like the LR standard ones, or the carbon fibre mesh - had these in my last 110 and they were fantastic. Picked them up on ebay for £50 brand new! Been looking at some of the Chinese kits on Amazon for this winter - very cheap but Will wait till there are a few more reviews... Quote Link to comment Share on other sites More sharing options...
Tim2809 Posted November 14, 2018 Author Share Posted November 14, 2018 58 minutes ago, Eightpot said: Waco do two different kits - there's a normal element type like the LR standard ones, or the carbon fibre mesh - had these in my last 110 and they were fantastic. Picked them up on ebay for £50 brand new! Been looking at some of the Chinese kits on Amazon for this winter - very cheap but Will wait till there are a few more reviews... will have a look. exmoor do a single heat kit for £110 or a pair of base elements for £75 Quote Link to comment Share on other sites More sharing options...
Tim2809 Posted November 18, 2018 Author Share Posted November 18, 2018 found complete waeco kit for similar money so although will need to change the switches im going for new kit as back rests elements still unknown. thanks for everyones input and help Quote Link to comment Share on other sites More sharing options...
