nickr Posted November 11, 2018 Share Posted November 11, 2018 My Defender rear diff pan was looking rusty, but not leaking. I decided this afternoon that a little bit of preventative maintenance was required, so out with the wire brush to give some quick prep before painting. Yep you've guessed it it now leaking! Looks to be a small area / pin prick hole. I've not replaced a diff pan before but i'm guessing is not an half our job, and one that will be easier to do with the axle off the vehicle. In any event I'm not going to be in the position to do it of a couple of weeks. MOT due next week as well. Has anyone got any suggestion on how i could make a temporary repair and what to use? Would something like chemical metal do the job? Thanks Nick Quote Link to comment Share on other sites More sharing options...
landroversforever Posted November 11, 2018 Share Posted November 11, 2018 Chemical metal might struggle if the surface has any oil on it. Quote Link to comment Share on other sites More sharing options...
nickr Posted November 11, 2018 Author Share Posted November 11, 2018 I'm currently draining the diff down completely and will leave for a couple of days, and will then clean thoroughly and decrease and clean off with acetone before applying anything. Quote Link to comment Share on other sites More sharing options...
Roverdrive Posted November 11, 2018 Share Posted November 11, 2018 Depending on where the hole is, it may be possible to screw a self tapper in and use chemical metal over the top after cleaning well with brake cleaner. Make sure you are nowhere near the crown wheel. I had the same issue on my Salisbury axle just before the MOT! Held fine for a month before replacing the bolt on pan Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted November 11, 2018 Share Posted November 11, 2018 I've drained the oil and put spots of mig weld straight onto the pan, with great care! Go slow so as not to blow holes. Worked fine, for years... In fact I am sure it is still like it maybe 10 years on! Quote Link to comment Share on other sites More sharing options...
landroversforever Posted November 11, 2018 Share Posted November 11, 2018 I welded up a mates diff pan which had a small crack.... few hot tacks rather than a bead. Didn't drain it, just a good wire brushing and wipe with alcohol (might have just been a rag). Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted November 12, 2018 Share Posted November 12, 2018 I've used plastic padding metal repair very good oil resistant etc Ultimately you will probably need a new Diff pan £35 ish no need to drop axle off just remove half shafts, diff and jack rear up to make diff pan more accessible for cutting and welding Probably 2 - 4 hrs work depending upon an individuals ability Quote Link to comment Share on other sites More sharing options...
Diff Posted November 12, 2018 Share Posted November 12, 2018 If you don't want to, or don't have time to do a strip down etc, there is another way. I have successfully repaired a diff a pan, a sump, and a leaking diesel tank on expeditions using chemical metal without draining. The trick is to use soap from a bar of soap first because it will stick to oily metal. Use a piece of soap made soft and pliable with water and press it into the hole or crack. Use just enough to stop the leak, then carefully degrease the area around the soap filled hole, roughen the area with some sand paper and carefully apply chemical metal. Job done. Regards, Diff. 1 Quote Link to comment Share on other sites More sharing options...
Farmerfred Posted November 15, 2018 Share Posted November 15, 2018 If you want to do a temp repair, make sure that the leaking area is clean and oil free and cover the area with araldite, that's 2 part epoxy resin glue, that will stop it, I did that on a leaking pan and it lasted 6 years up to the time I sold the vehicle. You will need to replace it with a new pan eventually. Don't forget to put some black paint or something on it when dry otherwise the MOT tester might see it and with his industrial tooth pick dig it off. Remember that oil leaks can mean an MOT fail now. Quote Link to comment Share on other sites More sharing options...
Eightpot Posted November 15, 2018 Share Posted November 15, 2018 Fibreglass resin is pretty good for sealing pinholes up as well. Quote Link to comment Share on other sites More sharing options...
Farmerfred Posted November 15, 2018 Share Posted November 15, 2018 Basically the same stuff as Araldite 2 part epoxy, only real difference is that with glass fibre resin and hardener it usually comes in larger containers whereas Araldite is in a handy twin 'syringe' pack so it won't cost you as much and it will keep longer. Quote Link to comment Share on other sites More sharing options...
