Sherwood01 Posted November 12, 2018 Share Posted November 12, 2018 Hi all just looking for advise i have a discovery td5 t reg and my interior light just refuse to work checked fuse new bulbs and even gutted new unit and still nothing Wondering if anyone else had this problem or knows what it could be. Quote Link to comment Share on other sites More sharing options...
teabag Posted November 13, 2018 Share Posted November 13, 2018 There should be a permanent supply to both units above for the purpose of the manual switch. Do u have that supply at the fuse and then up at the both lights. Quote Link to comment Share on other sites More sharing options...
ThreeSheds Posted November 14, 2018 Share Posted November 14, 2018 On 11/13/2018 at 11:15 AM, teabag said: There should be a permanent supply to both units above for the purpose of the manual switch. Do u have that supply at the fuse and then up at the both lights. Is it not controlled by the BCU? I seem to remember having trouble with mine not working until I locked and unlocked it or something like... Anyway - it didn't work, and then after a while it did. Sorry - not sure why. But keep messing and it might suddenly do it like mine did! What a useless post by me! Quote Link to comment Share on other sites More sharing options...
teabag Posted November 14, 2018 Share Posted November 14, 2018 Yes the interior lights are switch by the BCU on a D2. (MFU on a D1) But let’s start with simple things first, is there a 12v supply at the light fitting ? Quote Link to comment Share on other sites More sharing options...
finnarne Posted November 16, 2018 Share Posted November 16, 2018 Check the connector down in the footwell. Not sure if it's located in driver or passenger side, offside or nearside, but in my LHD, its down in the left footwell, which mean driver side to me. Mine has a lot of corrotion, and are due to a complete rebuild of some sort. replacing the contacts, or just solder every connector instead, I'm not sure. It our only driver at the moment, so I'm not going to touch it. Quote Link to comment Share on other sites More sharing options...
sierrafery Posted November 17, 2018 Share Posted November 17, 2018 It is C0484 on all ... the purple wires are the feed for the lamps Quote Link to comment Share on other sites More sharing options...
Clifford Garrett Posted December 2, 2018 Share Posted December 2, 2018 Did any of the advice provided result in you fixing your problem Sherwood01? A bit of feed back might be nice. Quote Link to comment Share on other sites More sharing options...
