Copland Posted November 13, 2018 Share Posted November 13, 2018 (edited) Hi I have a series one with a V8 and use the standard series 3 gearbox, my question is has any one managed to fit an Auto box ? If so, which box was used and what conversion ring and bell housing was used. Also was did you have to shorten your prop. Thnaks G Edited November 13, 2018 by Copland Quote Link to comment Share on other sites More sharing options...
secondjeremy Posted November 14, 2018 Share Posted November 14, 2018 I think Ashcroft used to do a kit - probably using a Borg Warner box. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted November 14, 2018 Share Posted November 14, 2018 No need for a conversion ring, just use a disco/rrc V8 auto box. They are 6" longer than an LT77 setup, which is longer than a series box setup. I know someone on here has an LT77 and 200tdi in their 80, but that is tight. So, with no dirt experience, I'd say it won't be fitting in there easily at all. Quote Link to comment Share on other sites More sharing options...
Chicken Drumstick Posted November 14, 2018 Share Posted November 14, 2018 Its certainly possible to fit a V8 and a ZF auto in an 80” Land Rover. Loads of CCV trials motors run this config. Although they are mostly on coil chassis not leaf. Many still retain the Series style front though. So I’d say it is perfectly doable. Quote Link to comment Share on other sites More sharing options...
Soren Frimodt Posted November 19, 2018 Share Posted November 19, 2018 At the 50th anniversary at brecon beacon? I crawled under an 80" with that exact setup, and boy was the rear prop short 😁 Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted November 19, 2018 Share Posted November 19, 2018 Well call me educated then! I am glad to hear the prop was short though! Quote Link to comment Share on other sites More sharing options...
Chicken Drumstick Posted November 19, 2018 Share Posted November 19, 2018 This one has a ZF 4 speed auto, 4.6 V8 and a Borgwarner transfer box. And still retains the inset front rad panel. Rear prop is short, but still works fine. Quote Link to comment Share on other sites More sharing options...
garrycol Posted November 20, 2018 Share Posted November 20, 2018 If that has the BW transfer box then they must have changed the axles etc as I understand the BW drive shafts are on the left not the right like other earlier transfer cases. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted November 20, 2018 Share Posted November 20, 2018 Nope, the RRC is standard land rover offset axles. The P38a drops the other way, iirc. Quote Link to comment Share on other sites More sharing options...
Chicken Drumstick Posted November 20, 2018 Share Posted November 20, 2018 10 hours ago, garrycol said: If that has the BW transfer box then they must have changed the axles etc as I understand the BW drive shafts are on the left not the right like other earlier transfer cases. Yes Transfer box is RRC not p38. I think the axles are actually D2 though. Quote Link to comment Share on other sites More sharing options...
garrycol Posted November 20, 2018 Share Posted November 20, 2018 Ok thanks for the clarification Quote Link to comment Share on other sites More sharing options...
