samwilk200 Posted December 21, 2006 Share Posted December 21, 2006 Hi all, Just wondering if anyone can give me the diameter of the safari snorkle where the flexi tube attatches just inside the wing?! If it makes any difference it will be one to go on the drivers wing! Thanks Quote Link to comment Share on other sites More sharing options...
GBMUD Posted December 21, 2006 Share Posted December 21, 2006 Hi all,Just wondering if anyone can give me the diameter of the safari snorkle where the flexi tube attatches just inside the wing?! If it makes any difference it will be one to go on the drivers wing! Thanks Is this a Discovery question? IIRC the Defender one picks up on existing plumbing... Chris Quote Link to comment Share on other sites More sharing options...
rick Posted December 21, 2006 Share Posted December 21, 2006 as GBMUD suggested, a Safari snorkel picks up the OE hose, which is 2,3/8" (61mm) ID (or convesely, the snorkel has a 2,3/8" OD spiggot) I reckon this is too restrictive and chopped it further back where it is 3" OD so that I could replace the entire hose between the wing and air cleaner with an 80mm ID hose. Quote Link to comment Share on other sites More sharing options...
samwilk200 Posted December 21, 2006 Author Share Posted December 21, 2006 its for a 90. I've just got some 3" hose, and hoped that would fit, then i could do one straight run to the air box. If its slightly tapered and can be chopped that solves my problem!! Quote Link to comment Share on other sites More sharing options...
