Sign in to follow this
Retroanaconda
200Tdi Head Bolts
Folks,
Can 200Tdi head bolts be reused, or are they single use only?
Workshop manual for 300Tdi is quite clear that they can be reused up to five times, however the 200Tdi manual implies that they must be renewed every time.
Share this post
Link to post
Not sure, I fitted new head bolts from Turners on the engine rebuild, but on a previous head gasket change I reused the original bolts with no issues.
Share this post
Link to post
We re-used mine last Christmas. No idea if they had been used before!
Share this post
Link to post
Unless you owned it from new, how would you know?  If it worth saving a little bit of money?
Share this post
Link to post
Thanks folks. I've sorted a new set so will use them. Just didn't want to do so unnecessarily if they could be reused.
Spare head has come back okay from the pressure test and been cleaned up and faced, so I just need to do the valve stem seals and then swap it over.
  • Like 1
Share this post
Link to post
13 minutes ago, miketomcat said:
I think the lr workshop manual says 3 times but definitely more than one use.
Mike
It says to use new bolts.
Share this post
Link to post
I beg to differ!
Gen or discovery manual.
Mike
Share this post
Link to post
My defender genuine manual says fit new bolts (200tdi), my 300tdi book says fit new bolts.
Share this post
Link to post
The manuals I have used in the past said 5 times for both Tdi versions.  Haynes says the same, and their data is from the LR manuals.
Share this post
Link to post
On the basis that I didn't know if mine had been reused prior to, I bought new bolts.
Mo
Share this post
Link to post
Seems an unclear picture from Land Rover, however I will use new ones as they’re cheap enough.
Aiming to do the head swap this weekend, despite having the car ten years it’s the first time I’ve done one so wish us well!
Share this post
Link to post
On 11/22/2018 at 1:08 AM, Scotts90 said:
Go gently with the t/stat housing bolts.
Or any bolt into ali/alloy - they need little more than nipping up.
Share this post
Link to post
Mine was good inside too, that looks ok.
after removing the pistons I found some semi circular cracks just below the oil control ring on the thrust side of pistons, 1,2, 3, 4 was OK. there were some shaded ares in the bores which were taken out by the 020 thou over bore.
Share this post
Link to post
