Zimlandy Posted November 24, 2018 Share Posted November 24, 2018 Hi, i am wanting to strip the dash out of a 92 110 Defender completely to create as much space as possible. I will put in aftermarket essential gauges. This is a vehicle used in photographic safaris and space to move is essential with bean bag rests. What all is hidden behind the dash? Anyone done this before? Quote Link to comment Share on other sites More sharing options...
Lightning Posted November 24, 2018 Share Posted November 24, 2018 I can’t imagine this being a great idea for the very small amount of extra room it would create. The pre-TDCi Defender/Land Rover has a pretty minimalist dashboard as standard. The best improvement would be made by removing the steering wheel/column, but then you’d only be able to drive in straight lines, could work in the African Savanna l suppose. Quote Link to comment Share on other sites More sharing options...
Zimlandy Posted November 24, 2018 Author Share Posted November 24, 2018 3 hours ago, Lightning said: I can’t imagine this being a great idea for the very small amount of extra room it would create. The pre-TDCi Defender/Land Rover has a pretty minimalist dashboard as standard. The best improvement would be made by removing the steering wheel/column, but then you’d only be able to drive in straight lines, could work in the African Savanna l suppose. Thank you for your input, i agree the space gained will be minimal but it will be some. i plan to move the steering wheel forward by a couple inches too. Quote Link to comment Share on other sites More sharing options...
HampshireHog Posted November 24, 2018 Share Posted November 24, 2018 If its ideas your after , type Land Rover dash into Pinterest , tons of ideas on there ,some good some not so good and some where the designer / owner has been at the hemp roll ups Quote Link to comment Share on other sites More sharing options...
dailysleaze Posted November 24, 2018 Share Posted November 24, 2018 It'd look something like this, plus removing the black metal plate at the top. Just the wiper motor and wiring is left exposed. And the heater and radio won't work! 😂 Quote Link to comment Share on other sites More sharing options...
Lightning Posted November 25, 2018 Share Posted November 25, 2018 Well l guess you could strip the lot out as above, obviously l was joking about the steering wheel but if you plan to move that forwards then you must be pretty serious about it. You might want to line the bulkhead with carpet or rubber mat to make it look a bit better and cover any sharp edges. l suppose a fuel gauge and speedometer is all you really need. The lights/windscreen wiper switches are on the steering column so no need to find a place for those. Quote Link to comment Share on other sites More sharing options...
roamingyak Posted November 25, 2018 Share Posted November 25, 2018 Funnily enough just stripped mine out yesterday. Are you in Zim? Do you need a heater at all? If not, you could... 1. Leave the drivers dash and steering wheel as it it, not worth the hassle to move for a few inches, easy to fix things then, resale value....... etc 2. Strip out as in the above picture, but also strip out the heater box in the engine bay, then mount the windscreen wiper motor (thing on the left of the photo) from inside the cab in its place. Then you have a saved about a foot of space from the door to the steering dash unit.. Send us some pictures with what you do... Quote Link to comment Share on other sites More sharing options...
roamingyak Posted November 25, 2018 Share Posted November 25, 2018 Easy to follow video here btw... Quote Link to comment Share on other sites More sharing options...
Zimlandy Posted November 25, 2018 Author Share Posted November 25, 2018 8 hours ago, roamingyak said: Funnily enough just stripped mine out yesterday. Are you in Zim? Do you need a heater at all? If not, you could... 1. Leave the drivers dash and steering wheel as it it, not worth the hassle to move for a few inches, easy to fix things then, resale value....... etc 2. Strip out as in the above picture, but also strip out the heater box in the engine bay, then mount the windscreen wiper motor (thing on the left of the photo) from inside the cab in its place. Then you have a saved about a foot of space from the door to the steering dash unit.. Send us some pictures with what you do... Yes i am in Zimbabwe, in Victoria Falls. I do a lot of safaris is Hwange National Park. I plan to strip out the wind screen wiper motor and heater for sure. The doors are coming off and i will be making new doors suited to photography. I have one more safari this week then will begin stripping the vehicle. I have aftermarket suspension to go on, redoing all the bushes, adding new safari seats and more. I will put pics up for sure. Thank you for the info. Much appreciated. Quote Link to comment Share on other sites More sharing options...
Zimlandy Posted December 2, 2018 Author Share Posted December 2, 2018 Well i have pulled all the dash out and am very happy with the amount of space it will add. I plan to get an Auto electrician asap to tidy up the wiring and thin it out as much as possible.I think i will end ups taking the wiper motor out completely and get a single one off the back on a car and use that for drivers side only and mount the motor in the bay. I plan to use sheet steel and bend it to mirror the shape of the bulk head now then maybe put tread plate in the foot well and paint a rubber liner everywhere else. I will be changing the steering wheel to something more comfortable and plan to have simple essential gauges in the steel probably where they were before more or less. Indicators , lights etc i plan to put on simple toggle switch. Any advice on any of this or other ideas greatly appreciated. Quote Link to comment Share on other sites More sharing options...
Lightning Posted December 5, 2018 Share Posted December 5, 2018 I think you are pretty much on your own with this, as it’s not something that many people will have ever done. But the steel liner sounds a good idea. Quote Link to comment Share on other sites More sharing options...
Eightpot Posted December 5, 2018 Share Posted December 5, 2018 (edited) I've often thought about pulling it all out and replacing it with a series 2 style dash - the whole thing is just a heater vent with a badly arranged bit of shelf. Edited December 5, 2018 by Eightpot Quote Link to comment Share on other sites More sharing options...
Lightning Posted December 5, 2018 Share Posted December 5, 2018 One way to murder the value of a Land Rover l guess. Unless it’s for a specific purpose as above with Zimlandy’s l wouldn’t go there. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted December 5, 2018 Share Posted December 5, 2018 I would do a Madman EMS for the gauges. You won't need a speedo, I assume. One gauge with alarms to monitor everything plus the warning light cluster. Quote Link to comment Share on other sites More sharing options...
Zimlandy Posted December 6, 2018 Author Share Posted December 6, 2018 13 hours ago, Lightning said: One way to murder the value of a Land Rover l guess. Unless it’s for a specific purpose as above with Zimlandy’s l wouldn’t go there. I bought it for two grand grand. Many many more of them lying around in Africa for much less and a little more! Quote Link to comment Share on other sites More sharing options...
