fearofweapons
Series III - Ignition Switch Woes
The diesel ignition switch, with steering lock, on the Series 3 was playing up so I ordered a new petrol one.
I ordered up part PRC8230R however on trying to fit it I found it was smaller than the lock mechanism and so would not fit. In addition I have no idea how the old switch ever worked - the bar from the lock to the old switch is far to small and has real problems turning it. However the bar is a good fit for the new switch.
Can anyone tell me what the correct part number is please for a 'fatter' petrol switch? Or am I better just buying a complete new assembly? In which case would an early 90/110 ignition switch with steering lock assembly fit or do I need a specific series III one?
The photos below show the old switch and how the bar does not really fit along with the outer dimensions of old lock. You can also see the new lock and how it does not fit.
As always any help much appreciated.
regards,
Richard
Share this post
Link to post
there is a small cast alloy adaptor that fits between that shaft and the switch module . Not sure on the diameter difference though
cheers
Steve b
Share this post
Link to post
cheers
Steve b
Thanks Steve - I wonder if that fell out when I removed the switch and is rattling around in the dash somewhere? It might be time to get one of my children, with smaller hands than mine, to have a furtle...
Share this post
Link to post
It will be down there somewhere :) , it may fall out if you take the screws out of the lower edge of the bottom section and move it away from the bulkhead , been there before myself
cheers
Steve b
Share this post
Link to post
I'd be interested in finding a new one of those tiny little  bits too, mine disintegrated and I'd like to save the original ignition barrel.
Share this post
Link to post
Fridge - I would have sent you mine if I found it ( I couldn't despite finding some quite amazing 'dashboard fluff' down the crack. )
On Saturday we replaced the whole thing with a new switch, steering lock and key assembly. I immediately noticed an improvement in starting - the car now starts on the first turn of the key with no cranking - so the switch must have been fairly bad when we bought the car. Also the key now goes in and out with minimal wiggling - before it would sometimes get stuck.
Now I just need to work out what on earth the relay does that is wired into the live feed to the switch and the relay output into the coil - so the coil would appear to be always energised... oh you gotta love PO shenanigans with wiggly fizz. Time to put on my well insulated boots I fear.
Share this post
Link to post
Haha, thanks! If it ever turns up let me know :unsure: as I'm fairly sure it's not available separately and it's a hell of a fiddly little thing to try and make.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
