georgega1003 Posted December 2, 2018 Share Posted December 2, 2018 (edited) Will a Defender stearing weal fit my series 3. Edited December 2, 2018 by georgega1003 Quote Link to comment Share on other sites More sharing options...
Chicken Drumstick Posted December 3, 2018 Share Posted December 3, 2018 weal1 /wēl/ noun a red, swollen mark left on flesh by a blow or pressure. MEDICINE an area of the skin that is temporarily raised, typically reddened, and usually accompanied by itching. Quote Link to comment Share on other sites More sharing options...
Gazzar Posted December 3, 2018 Share Posted December 3, 2018 Nah, might not be native English speaker, or may be a dyslexic. But the answer is, probably not. The spline count is different for standard wheels. Bit why would you fit a tacky plastic steering wheel to a series vehicle? Quote Link to comment Share on other sites More sharing options...
Arjan Posted December 3, 2018 Share Posted December 3, 2018 IIRC the first Ninety and OneTen models had the same amount of splines. Quote Link to comment Share on other sites More sharing options...
Snagger Posted December 6, 2018 Share Posted December 6, 2018 On 12/3/2018 at 9:20 PM, Arjan said: IIRC the first Ninety and OneTen models had the same amount of splines. Nope, it's the chunky Tdi steering wheels that fit. The hard 4-spoke and TD5/Puma wheels with removable centre boss both share the same splines as eachother, so you can swap those generations of "Defenders", but not fit them to a Tdi or Series. Metro and Montego wheels fit the Series columns, but you'll need to adapt the collar from the back of the Series wheel to press against the column bearing preload spring and for the indicator self cancelling. Quote Link to comment Share on other sites More sharing options...
western Posted December 6, 2018 Share Posted December 6, 2018 http://www.web-rover.co.uk/articles-steeringwheels.html You will have to count the splines on the Series column to see if it's 36 or 48 spline, then make your choice from the types in the link above, also some older Austin Rover car steering wheels fit as well. Quote Link to comment Share on other sites More sharing options...
neil110 Posted December 13, 2018 Share Posted December 13, 2018 The wheel from a 300Tdi will fit a series 3 steering column, a friend had one fitted to his for years Quote Link to comment Share on other sites More sharing options...
