jimconline Posted December 6, 2018 Share Posted December 6, 2018 Any thoughts as to why the blower runs intermittently on high speed? Sometimes when I switch from low to high it works; other times it doesn't. If I leave it on high it will start and stop when it feels like it. Low speed always runs. I've tested connections from the fan control (replaced a couple of years ago) on the dash through to blower motor; no issues noted. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted December 6, 2018 Share Posted December 6, 2018 Probably the switch, but the reality is you need to troubleshoot with a meter when it happens. Step one, get the wiring diagram and understand it. Quote Link to comment Share on other sites More sharing options...
jimconline Posted December 6, 2018 Author Share Posted December 6, 2018 As mentioned, I tested connections from control through to blower; I have and understand the wiring diagram. Problem is it cuts out and comes back on so randomly and quickly I can't catch it when it's off. As you suggest, I'm thinking it's the switch. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted December 6, 2018 Share Posted December 6, 2018 Testing when the fault is not occurring is of no use. The switches are not very well designed. Quote Link to comment Share on other sites More sharing options...
jimconline Posted December 7, 2018 Author Share Posted December 7, 2018 Problem was the harness connector at the blower motor. I had suspected this early on, tested it, cleaned it, and all was working until recently. Finally decided to recheck and was able to get the high speed fan to stop and start by wiggling the connector. Obviously only the pin for the high speed line was compromised since the low speed fan never failed. Will replace plug. Quote Link to comment Share on other sites More sharing options...
