Tom17 Posted December 6, 2018 Share Posted December 6, 2018 Hi all I'm going to attempt to retrim the back of my 90 with rubber check plate. I plan to dynamat it and foam it before installing the rubber. Can anybody recommend anything to stick down the rubber? I've attached a photo of what I'm hoping to achieve. Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted December 6, 2018 Share Posted December 6, 2018 Sikaflex polyurathane mastic would do it i guess its what they use for car windscreens very very strong Quote Link to comment Share on other sites More sharing options...
paime Posted December 7, 2018 Share Posted December 7, 2018 When i did mine the matting itself was quite heavy so a bit of double sized tape holds it all in place. It's a one-piece mat though so i imagine if you cut it up to fit different surfaces then i'm not sure it'll work. I also wouldn't go for anything too permanent as you'll want to take it off and clean/dry the floor every so often. Quote Link to comment Share on other sites More sharing options...
Eightpot Posted December 7, 2018 Share Posted December 7, 2018 (edited) Screwfix spray adhesive will do it. £6 a tin. Edited December 7, 2018 by Eightpot Quote Link to comment Share on other sites More sharing options...
Maverik Posted December 10, 2018 Share Posted December 10, 2018 Trim contact adhesive I'd give a go. its generally pretty good for not reacting with stuff or it would be useless on a lot of the reasonably delicate trim materials. Been using "Trim fix Adhesive" on the van recently comes in a red can, surprisingly strong stuff - used it to fix down some Altro flooring. Quote Link to comment Share on other sites More sharing options...
