Tomwykes Posted December 12, 2018 Share Posted December 12, 2018 Hi all, new to the forum but not to land rovers. Although this is my first diesel one. My daily drive is an X military 110, fitted with a 200tdi. Last week my stop solenoid stopped working meaning I had to stall the engine to stop it. However I discovered if I had the headlights on the stop solenoid would work. Fine lived with this. But then my indicators would only work with the headlights on yesterday. But now the headlights won't turn on. I'm guessing an earth issue. The main strap, battery to chassis is good I took it off and cleaned it all up. But I can't find where any other multiple, minor, earth points are. Or is everything earthed locally? Suggestions, questions please. Tom. Quote Link to comment Share on other sites More sharing options...
western Posted December 12, 2018 Share Posted December 12, 2018 Earth cable from engine to chassis. Multi earth's on bulkhead adajent to clutch pedal housing, look for multiple plain black wires to a single screw. Quote Link to comment Share on other sites More sharing options...
Tomwykes Posted December 13, 2018 Author Share Posted December 13, 2018 Thanks Western. Turns out to be the military, rotary light switch. Ignition goes through it too, time to replace the switch. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted December 13, 2018 Share Posted December 13, 2018 Squirt it with a load of contact cleaner and work it, it will most likely start working again, they are pretty robust. 1 Quote Link to comment Share on other sites More sharing options...
