Arjan Posted December 16, 2018 Share Posted December 16, 2018 As per title.. We're getting to the stage where the Series Hybrid is coming back on the road and I could do with a diff lock. I hace a Defender diff with an Ascroft Locker in it sitting at the shelf but I'm not sure I want that as I'll have an upgearing due to the higher ratio and that is in all gears - and I like 1st Low to be justthat : slow.. Let me have your suggestions please ? Quote Link to comment Share on other sites More sharing options...
Jon White Posted December 17, 2018 Share Posted December 17, 2018 What gearbox, what transfer box and what size tyres? Quote Link to comment Share on other sites More sharing options...
Arjan Posted December 17, 2018 Author Share Posted December 17, 2018 Standard Series tranmission 235/85 R16 tyres Quote Link to comment Share on other sites More sharing options...
Gazzar Posted December 17, 2018 Share Posted December 17, 2018 Ashcroft LSD plus Ashcroft series ratio crown and pinion. Ashcroft series shafts. Done. Forever. Quote Link to comment Share on other sites More sharing options...
Gazzar Posted December 17, 2018 Share Posted December 17, 2018 That's as low ratio as one can get in a series, with out going for the 1 tonne transfer box. And I'm not sure that had a different low ratio, it was the upper range that was slow. G. Quote Link to comment Share on other sites More sharing options...
Arjan Posted December 17, 2018 Author Share Posted December 17, 2018 I will not have Ashcroft transmission stuff - I have had some very, very bad experiences with them. Let me explain a bit better the question as I am not a native English speaker. I have a lockable diff here that I could fit to the Series - but it causes a higher final ratio drive and in Low I really like to go slow in Low. Are there for the Series diffs LSD or lockable diff options ? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted December 17, 2018 Share Posted December 17, 2018 I think the answer is second hand ARBs, Arjan, RD03s I think they are. They aren't the best design, carry the older style locker and of course being so old, are mostly worn out now. You can fit the 4.7 crown wheel to the later diffs in a lot of cases, though you either need a spacer as the original 4.7 crownwheel is thinner, or an aftermarket 4.7 crownwheel, designed for the later coiler diffs. I know Soren's little 80" on here is running 4.7s, and Ashcroft 'coiler' ATBs, with some sort of coiler halfshaft trimmed to fit the 24 spline diff and different drive flanges. Quote Link to comment Share on other sites More sharing options...
Snagger Posted December 17, 2018 Share Posted December 17, 2018 The locking diff can be any ratio if you change the crown gear. However, the pinion diameter is different for different ratios, and on 4.71 ratio diffs, the crown gear flange is further away from the pinion axis to allow for that. It means a 4.71 gear set can be fitted to a diff fitted with 3.54 gears (4.1 and higher use the 3.54 diff centre), with the use of a simple spacer ring between gear and flange, but you can't fit taller gears to a 4.71 diff centre. So, if I understood correctly what you have, you could fit the Defender's diff if it's 10-spline and you use the spacer ring. Otherwise, you need a Series dedicated LSD/ATB?locker. I don't think LSDs are a great option due to the maintenance needed. ATBs are good though. You can get Rover and Salisbury types from Eaton in the Trutrac and from Quaife (much better, but also much dearer). I think all the usual suspects make Series compatible Series locking diffs, including Eaton/Detroit and ARB. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted December 17, 2018 Share Posted December 17, 2018 Odd, I thought that last time I looked the Truetrac wasn't available for Series, but Ashcroft seem to have a solution to the metric/imperial bearing issue: https://www.ashcroft-transmissions.co.uk/limited-slip-differentials/detroit-truetrac.html I remember the ashlocker not being available in 10 spline when it debuted. Quote Link to comment Share on other sites More sharing options...
Snagger Posted December 17, 2018 Share Posted December 17, 2018 I don't know that any Ashcroft diff is suitable for Series vehicles, but if they have 10 spline units, they'd fit. The bearing sleeves may be needed for non-metric cases. The Trutrac is available in 10 spline, but does need the bearing sleeves if fitted to the Series (Imperial) casing: https://www.lrparts.net/vehicle/series-2-2a-3/axle-and-drivetrain/diff-lockers-drivetrain-upgrades/diff-lockers-and-slip-diff.html This company is also the cheapest I have found for the Trutrac in the UK, and cheaper than buying in the US and shipping. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted December 17, 2018 Share Posted December 17, 2018 Nige / Hybrid_From_Hell should be able to tell you what can be done with a Series-ratio diff by way of upgrades / lockers etc., I'm sure anything's possible even if it's not "normally done"... his website: https://www.megasquirt-v8.co.uk/diff_upgrade.php Quote Link to comment Share on other sites More sharing options...
Arjan Posted December 17, 2018 Author Share Posted December 17, 2018 Thanks - I' ll sent him a message Quote Link to comment Share on other sites More sharing options...
Gazzar Posted December 17, 2018 Share Posted December 17, 2018 There's a set of hd series diff crowns on the "for sale" section iirc. Ask Nige about them. G. Quote Link to comment Share on other sites More sharing options...
Arjan Posted December 17, 2018 Author Share Posted December 17, 2018 Thanks ! Talking to Nige as I type.. Quote Link to comment Share on other sites More sharing options...
Daan Posted December 17, 2018 Share Posted December 17, 2018 As mentioned, the 4.7 ratio fits with a spacer. I would also ditch the 10 spline shafts, as I broke many of those on my old series, and that was without a difflock. Daan Quote Link to comment Share on other sites More sharing options...
