Stellaghost Posted December 20, 2018 Share Posted December 20, 2018 (edited) Have dug this out of the depths of my garage just wondering if any one in the forum has an instruction manual have not tried to see if working and don't know if it is all there any help appreciated thanks in advance Edited December 20, 2018 by Stellaghost Spelling Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted December 21, 2018 Author Share Posted December 21, 2018 Had a wee bit tinker about this morning with the above seems to be working fine on the series injectors I tried just need to decide if I actually need it or not as had it for years and only tried it out of curiosity you know how it goes when you get something in your head Quote Link to comment Share on other sites More sharing options...
Paddy_SP Posted December 24, 2018 Share Posted December 24, 2018 It looks like a nice piece of kit - do you know the make/model? If so, it might help someone come up with a manual! Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted December 24, 2018 Author Share Posted December 24, 2018 Its a Cav part no 7144'664 Quote Link to comment Share on other sites More sharing options...
Zeberdy Posted October 6, 2021 Share Posted October 6, 2021 Hi Did you get any joy obtaining any instructions for the CAV Injector tester? I have exactly the same unit pulled out if garage been there for years and have a need to check some injector Pop pressures. Thanks Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted October 6, 2021 Author Share Posted October 6, 2021 1 hour ago, Zeberdy said: Hi Did you get any joy obtaining any instructions for the CAV Injector tester? I have exactly the same unit pulled out if garage been there for years and have a need to check some injector Pop pressures. Thanks Sorry I didnt, but it's easy enough to figure out you would just need the expected figures from injector manufacturer to see how yours pop in comparison regards Stephen Quote Link to comment Share on other sites More sharing options...
Zeberdy Posted October 6, 2021 Share Posted October 6, 2021 Thanks for reply, did you clean yours out and replace/ clean filter it mentioned on label. Assume you can fill it with Diesel oil ? Not really examined it too much yet has one connection with pipe and union for injector and valve on back perhaps this is to release pressure before disconnecting. I did find an American forum someone said had instructions but not for copy yet. Thanks Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted October 6, 2021 Author Share Posted October 6, 2021 1 hour ago, Zeberdy said: Thanks for reply, did you clean yours out and replace/ clean filter it mentioned on label. Assume you can fill it with Diesel oil ? Not really examined it too much yet has one connection with pipe and union for injector and valve on back perhaps this is to release pressure before disconnecting. I did find an American forum someone said had instructions but not for copy yet. Thanks Yes you've got it, fill with diesel, pump it up and valve to release/lock in pressure regards Stephen Quote Link to comment Share on other sites More sharing options...
Zeberdy Posted October 7, 2021 Share Posted October 7, 2021 I managed to find some info on the CAV injector tester so have shared it below in case it helps anyone in future. Regards 2 Quote Link to comment Share on other sites More sharing options...
