Snorkel tube to roll cage bracket
daveturnbull
I'm finally getting round to replacing my butchered southdown snorkel with a new stainless pipe, but need some way to mount it to the roll cage. Snorkel is 3" tube, roll cage is 1.5". I don't mind welding something to the cage, but would rather leave the snorkel alone.
Lets see your creations for inspiration.
So a big question that could impact the solution a lot is are the snorkel and cage tube running parallel to each other?
Or does the solution need to accommodate an angle?
My thoughts are some type of P Clip or other pipe or cable bracket or cleat for the snorkel and then another for the cage or weld on mounting point.
e.g.
https://www.jtmplumbing.co.uk/pipe-fittings-c433/rubber-lined-unlined-steel-pipe-brackets-c244/jtm-bracketry-rubber-lined-steel-pipe-cl
or
https://abbeyclamps.co.uk/products/p-clips-saddle-clamps/klamp-works-standard/
or
https://www.jointingtech.co.uk/Single-Bolt-Heavy-Duty
I've used similar for water hose mounting.
Edited by zardos
PPCages make some nice clamps with a single bolt in the middle so they take up any difference in tube diameters. Can't find a picture of them, but they're like two shallow 'm' shapes that go one on each side and a single bolt in the middle.
EDIT: I lied.... it's Devon 4x4.... https://www.devon4x4.com/d44-snorkel-roll-cage-clamp.html
Problem with any p clips, clamps or tyraps etc. as mentioned so far is that it does ok to keep the snorkel in place against wind, but clouting it against a tree is going to result in your snorkel being pushed against or through the screen.
To protect it against this weld the clamp to the cage or fabricate a bracket to do this, like so:
I have a 2 mm stainless band around it which bolts to the bracket with  m6 nut and bolts. on both ends.
Another bracket on the top screen rail stops it from rotating. This is a 3" snorkel.
Daan
How about using either a jubilee clip or mikalor clamp with a shaped piece of nylon or Ali in between the cage and snorkel. So a triangle of nylon with the cage radius cut in the point and the snorkel radius in the base. Then the clamp around the lot, you may need a small fixing or location blob to stop the infill from moving.
Mike
