BogMonster Posted December 29, 2018 Share Posted December 29, 2018 I have had (for many years) a Milemarker H12 with the hydraulic pump that mounts on the 300Tdi aircon slot, as sold by the supplier who I think was called ?Alfred Murray Ltd back in the early 2000s. It's on its third vehicle (where it has been for 12 years) and has never missed a beat. AM seems to have gone by the way over the years (the bookmark I have for 4x4winches.com has gone), as does Milemarker in the UK - I've seen First Four selling some spares for them I think, but not seen a winch for sale anywhere for a long time. Milemarker in the US still seems to exist, but I'm pretty sure the Land Rover fitting kit was something pulled together by the UK agent using some sort of power steering pump. I have noticed that the winch doesn't seem to pull as much as it used to before the relief valve opens. Still a lot of power in low range but you can now stall it, which used to be impossible. I have no idea where the valve is or how it operates - but I presume it's internal to the pump somewhere, rather than in the winch body. Does anybody know anything about these, to be able to to suggest what the issue might be and whether or not it's realistic to fix it? I don't even know what the make and model of the pump was at the time, or whether it (or spares) are still available. Quote Link to comment Share on other sites More sharing options...
steve b Posted December 29, 2018 Share Posted December 29, 2018 I'd start by checking the mechanicals of the winch - drum bearings , alignment of end castings and gear assy. then oil feed pipe to pump and whatever filter you have either in the return or suction line . If you have an OCV ~hydraulic lock ~ it may be that it needs adjustment or is failing . The PRV is usually located in the spool valve block and often covered by a closed cap nut , under it will be a long "grub screw " and a lock nut , it should be around 170 - 180 bar to protect the motor . hope that gives you some pointers Steve b Quote Link to comment Share on other sites More sharing options...
BogMonster Posted December 29, 2018 Author Share Posted December 29, 2018 The pump supplied is a PAS pump off something or other I think, so probably internal relief? The Alfred Murray solenoids are a very compact solenoid block, I don't really think it is inside that but I'll have a look. No OCV, cooler or anything like that - the AM kit was pretty basic to keep the cost reasonable, a small PAS reservoir supplies Dexron PAS fluid to the pump. through the valve block to return to the reservoir or divert to the pump when the in or out solenoids are triggered. The thing doesn't sound any different to before, just seems to open earlier than I think it used to. Quote Link to comment Share on other sites More sharing options...
steve b Posted December 29, 2018 Share Posted December 29, 2018 Ah , yes , you are probably right about the prv location , maybe stick a washer under the relief spring to test ? or maybe run thicker hydraulic oil (SAE 46 ) to see if that makes a difference ? A mate of mine runs 15/40 diesel engine oil in his U900 Unimog hydraulic tank . How often do you change the oil ? Iirc the kits had ZF74 pumps ? Does it run all the time or is there an EM clutch ? Steve b Quote Link to comment Share on other sites More sharing options...
BogMonster Posted December 30, 2018 Author Share Posted December 30, 2018 4 hours ago, steve b said: Ah , yes , you are probably right about the prv location , maybe stick a washer under the relief spring to test ? or maybe run thicker hydraulic oil (SAE 46 ) to see if that makes a difference ? A mate of mine runs 15/40 diesel engine oil in his U900 Unimog hydraulic tank . How often do you change the oil ? Iirc the kits had ZF74 pumps ? Does it run all the time or is there an EM clutch ? Steve b Yeah, ZF74 rings a bell. It runs all the time, no clutch. Old photo of it in the vehicle before last when it was all shiny and new: Fluid, er gulp about 2007 when it was fitted to the current vehicle? still nice and clean and red in the tank, and doesn't get used that often so mostly it's just circulating through the pump. Quote Link to comment Share on other sites More sharing options...
steve b Posted December 30, 2018 Share Posted December 30, 2018 With the low total volume of fluid in the system I'd be changing it annually just for peace of mind , I reckon it will fix the difference in performance you have noticed cheers Steve b Quote Link to comment Share on other sites More sharing options...
Arjan Posted December 30, 2018 Share Posted December 30, 2018 Give Peter Lamb (FirstFour) a call - he knows his winches.. Quote Link to comment Share on other sites More sharing options...
Escape Posted December 31, 2018 Share Posted December 31, 2018 I contacted Peter a few weeks ago for parts as I'm rebuilding my Milemarker. This is what I got as reply: Quote The situation with Milemarker has changed a lot in the last 2 years or so. They no longer supply EU re-sellers directly, but use an agent. This made sourcing winches and parts very difficult. Eventually we took a decision to cease supplying hydraulic winches completely. We still have some parts in stock, but these are getting quite low now. The parts listed on the website should be what we actually have left in stock. They also still have a hydraulic drive section, so definitely worth contacting. If you can identify the problem, any hydraulic specialist should be able to help you sort it. Filip PS: It's a real shame there's not much support anymore for Milemarker in Europe, real fine winches! Quote Link to comment Share on other sites More sharing options...
BogMonster Posted January 1, 2019 Author Share Posted January 1, 2019 Thanks, I will have a play but if it looks too difficult to get spares then I'll probably just get an electric winch instead. I got the impression that neither the valve block nor the pump supplied by AML were Milemarker parts. Quote Link to comment Share on other sites More sharing options...
Ed Poore Posted January 1, 2019 Share Posted January 1, 2019 How does water in oil affect the operation of PRVs? Given the small volume I'd be inclined to change it as if it's got water in either by leakage or condensation it'll affect it's operation. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted December 7, 2019 Author Share Posted December 7, 2019 Months later the pull had deteriorated to a low level and I discovered slightly by accident that it's because the belt has stretched and the pump is stalling under high load. And the spare belt I bought with it in 2003 or thereabouts seems to have drifted off in the meantime.... From the installation photos (writing long gone from the belt itself) it is a Dayco 4PK0830 i.e. 4 grooves and 830mm. Does anybody happen to have a 300Tdi with aircon fitted, and if you could, please could you look on the belt and tell me what the spec is? It will be a 4PK something to fit the pulley on the engine, just wondering how long they are ... no way I am going to be that lucky Quote Link to comment Share on other sites More sharing options...
Ed Poore Posted December 7, 2019 Share Posted December 7, 2019 I'll try and remember to take a look tomorrow. I've got an aircon pump on mine for the diffs. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted December 7, 2019 Author Share Posted December 7, 2019 Thanks. Have ordered one off eBay but with Christmas post it probably won't get here before the holidays, so if it is the same as a 300 aircon belt then I might find one locally. Quote Link to comment Share on other sites More sharing options...
Ed Poore Posted December 7, 2019 Share Posted December 7, 2019 OK, not been outside to check but I'm fairly sure that my belt (which is for the air-con) is a ERR2215 which is a 4PK1322. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted December 8, 2019 Author Share Posted December 8, 2019 Thanks, that's miles too long then. I have tightened it but I think the grooves are probably worn as it still slips a bit if you stall the winch in high. New one should be here in a few weeks so it'll do until then Quote Link to comment Share on other sites More sharing options...
Ed Poore Posted December 8, 2019 Share Posted December 8, 2019 Silly question but you do have it routed the correct way around the pulleys? I thought mine was miles too long until I realised I'd got it routed the wrong way. Mind you the air con drive pulley is about 4" in diameter so if you've got a smaller pulley on the pump then I can see it being too short. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted December 8, 2019 Author Share Posted December 8, 2019 The Milemarker pump has a different arrangement to aircon. There is no idler or tensioner - the belt goes from the fan pulley straight up to the pump pulley, and nothing else - tension on the belt is set and adjusted by a tensioner bolt on the pump which jacks up one end of it slightly. Quote Link to comment Share on other sites More sharing options...
Ed Poore Posted December 8, 2019 Share Posted December 8, 2019 Is it worth changing to the aircon setup? You'd get a bit more of a wrap around the pulley which will mean you can transmit more power through the belt or cause it to slip less as there's more friction. That's why they have that setup, when the pump kicks in you can feel the engine coming under load. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted December 8, 2019 Author Share Posted December 8, 2019 Could do I suppose. Without having one to look at, I am not sure if an aircon tensioner would work on this setup, but it might. The current system has worked well since about 2003 and is now on its third vehicle, with this being the first problem in all that time, so I will probably leave it be. Quote Link to comment Share on other sites More sharing options...
Ed Poore Posted December 8, 2019 Share Posted December 8, 2019 The tensioner replaces the blanking plate on the front of the timing cover. The idler pulley sits on the threaded boss below it. To tension you put a 1/2" breaker bar into the centre of the tensioner to, well, tension it and then nip up the three bolts that go into the timing cover. Only reason for suggesting it would be off the shelf parts and potentially more wrap around on the pump. But if the pulley on the pump is much smaller I don't think you'll take out the slack in the standard belt so no better off. Although you do have additional adjustment in the pump itself by the sounds of it. Quote Link to comment Share on other sites More sharing options...
