FridgeFreezer
Cheap-ish welding helmet recommendations?
There's plans afoot to teach my better half how to weld :ph34r:, but currently I only have my Speedglas helmet and I'm not keen to invest quite that much in a backup / spare which may or may not see very much use.
I don't trust the £15 Chinese eBlag ones, and someone on here recently had a Screwfix one (I think) go bad... so any suggestions in the mid-price reasonable-quality sort of zone?
Share this post
Link to post
I have an eBay special big view one. Had it about five years and seen regular use. It was about £80 if you can bring yourself to trust it I think it’s a reasonable trade off between usability and price. It also looks like a blue skull so I can weld more better with it.
  • Haha 1
Share this post
Link to post
R-tech welding have some cheaper ones. Their machines have good reputations (I have 2), so I'd be inclined to trust their helmets.
Share this post
Link to post
Machine mart do some for £50 ish don’t know how good they are but there welding machines are reasonable.
Share this post
Link to post
Ideally 4 sensor screens that will switch at low amps will work best on vehicle repairs or thin low power bench work .  Have a look on www.wirs.co.uk  they are the most competitively priced on industrial spec stuff ~ I have a Miller Elite , they do have cheaper units
cheers
Steve b
Share this post
Link to post
I bought one of these recently, reckon it works very well used it when my footwell was welded in a few weeks ago. the guy who did the welding used the same helmet,
https://www.wellyweld.com/products/BritArc-3037-Variable-Welding-Headshield-72563.aspx
the place I bought mine from has a shop in Fareham  https://www.wellyweld.com/depots/fareham.aspx
Share this post
Link to post
My R-Tech helmet is excellent, particularly for the £80 £65 price tag.
Edit: pretty sure it's one of these:
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F172406601716
Edited by lo-fi
Share this post
Link to post
Avoid the parweld 4 sensor, mine has been swapped out twice for failing sensors under warranty...so unreliable it only does grinding duty.
Will your budget stretch to the cheaper Speedglas? I still use my first speedglas 100 for MIG, 13yrs and still works great.
Share this post
Link to post
2 hours ago, HoSS said:
Fixed lens, just no. PITA.
Absolutely!
I paid £60 for a small-window version a few years back, still works perfectly fine now.
I would go to a bigger window if buying one now, when in awkward spots it can make a big difference to visibility.
Share this post
Link to post
16 hours ago, Red90 said:
Just get a fixed lens helmet.  They always work.
Fixed lense is literally the last thing you want when learning!!
Share this post
Link to post
Meh.  I don't think it makes much difference really.  Auto lens are handy when you are in a difficult spot that makes lowering the helmet hard.  When learning, you will be in a really easy position and lowering the helmet is simple.
I'm also assuming he is teaching MIG and there is little use for auto darkening as you are not moving during a start.
Share this post
Link to post
Still gives you two hands free.
Share this post
Link to post
You don't use your hands to lower a welding helmet.....
Share this post
Link to post
I do. I suspect others do too. I've had too many tweaked ears or pulled hairs, or displaced hearing aids to let it do it automatically.
With a smaller viewing panel, the resting position is more important as well, so by hand it is. Of course you only need to lift it when you finish welding, not each time you pause or move the torch to a new spot.
It may not be what you do, but clearly you are more accomplished than I am.
Share this post
Link to post
My original one died and needed a replacement fast so cue Amazon Prime and sourced a Tacklife PAH03D for £60 and I've been genuinely very very impressed with it. Use it for both TIG and MIG and grinding. Came with a bunch of spare parts, case and has replaceable batteries which I wouldn't normally expect on something this price.
I've never experienced an expensive helmet but a friend who has and compared this very favourably, particularly even before you considered the price point.
Share this post
Link to post
I have one, it cost me £3 and it's worth every penny. There's a reason the world uses auto ones now and there's a reason I spent as much on my Speedglas helmet as my MIG - it's because it makes the whole job so much nicer in so many ways. You can work faster, see more clearly, be more accurate, work in confined spaces, and easily spot when you're on fire :SVAgoaway:
  • Like 3
Share this post
Link to post
Because it's a whole lot easier. Even with MIG there's a chance you'll waggle around and not see until you've got an arc.... by which point the weld is nowhere near where you wanted it. And as a beginner there's even more chance, even if you can rest the torch while you're welding.
  • Like 1
Share this post
Link to post
I have to disagree Ross.
When I learned to weld that was all there was, and I can't say it was a problem. Mastering the helmet nod was just part of learning to TIG.
Fix lenses ain't so bad really. Sometimes I still use mine when MIGing under a car as it can help with access. We are very spoiled today.
Share this post
Link to post
We will just need to disagree.  I've worked in the the welding fabrication business for 30 years. I have worked with hundreds of welders all over the world.  I've seen dozens of people learn to weld.
Share this post
Link to post
I can't use a fixed helmet because of where I live.
Share this post
Link to post
look at r-tech kit.
just spent a bit of time on their website myself.
used rtech stuff befer and have no issues with it. always wise to stump up for a couple of spare lense covers.
Share this post
Link to post
Where, civilisation?
Share this post
Link to post
I was going to say "2019" but yes, you guessed it! :SVAgoaway:
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
