World War Willys Jeep - from 1990 - Body mounted.
10 hours ago, Anderzander said:
Could you run it off a flexible shaft ? 😉
I can predict the outcome of that.
And making the same mistakes, while expecting a different outcome is the first sign of insanity.
Daan
On 1/21/2022 at 10:36 AM, landroversforever said:
Any option for one of the starter/generator things used in some new stuff?
That is way too new fashioned for this build!
40 minutes ago, Wytze said:
Daan,  do you have room to mount it the other way round?     I did that on the Mini  round nose with a Suzuki G13B.  Turned the altenator around in the wing.
I do, but I don't want to. Will cross that bridge when I come to it.
Daan
  • 3 weeks later...
Love the creative approach to bending,! and that is a tough ol' bit of stuff. And a nice job too, results look great. It is nice to have the genuine 1/4 plate,...I get that 6mm seemed like a step down but I am sure it would have been fine in practice. Nice not to have to though.
  • Like 1
3 hours ago, Carloz said:
6mm or 6,35mm... Big deal. :D The (unkown?) material quality is a bigger factor...
But well, progress there is! 🙃
The difference is 0.35mm, or 6%. Not much, but because the spring is much wider (about 40%, since I  started in percentages), the bending force on these is much greater. So I made them much deeper compared to original. Surely 6mm would have done it, but given the option, I thought 1/4" would be better.
Daan
The material is good old British made steel produced in the days when quality wasn't sacrificed for profit.
Which is more than I can say for the stuff we had fitted on a massive project at work, 10 mm plate steel wearing through only 3 months after installation on around 30% plant usage, proper good chineseium..............
Regards Stephen
  • Like 2
  • Sad 2
  • 4 months later...
  • 4 months later...
Hi, here we are again with a (long overdue) update. Summer was mainly spent entertaining my family and seemingly came and went in a flash. So here we are, 9 months and 2 prime ministers later, I have something new to show; I decided to have a clear out of my garage by mounting parts to the chassis, starting with the largest lump, engine and gearbox. Now I have the body, I could take measurements to check for any potential clashes with the VW TDI. It shows that the Mahindra is different in a few areas to the Willys body I have. The gearbox is mounted further backwards compared to the Willys, and is also longer, it being a 4 speed. As a result, the engine rocker cover flange of the VW has no clearance to the bulkhead, and the gear stick does not line up with the hole in the tunnel. More interesting things are happening once I tried to fit the prop shafts; They are too short. The rear by about 5mm, which is the result of the parabolic springs drooping much further due to them being quite soft. (This is all done with the axles hanging of the springs). The front prop was more worrying, as it somehow was too short by about 1 inch. After some measuring, it appears the Dana 30 diff I use is 1” shorter than the Dana 27 it replaced.
So, a few problems to think about (plus many more, but for another time). After some head scratching, I decided best solution is to move the engine and box forward by about 30mm solving all these problems. It will need a longer rear prop, which is a good thing, as the Mahindra one is comically short, resulting in unhealthy U/J angles at full droop. The U/J’s are Identical to Defender ones, so it should be easy adapt a defender prop.
With the location decided on, I could start fabricating engine mounts. I am using the original Hydraulic mounts that came with the engine (It is a 1.9 TDI 110 out of a Passat B5, engine code AFN, not the 90 HP version I thought previously). I am mimicking the original setup of the Passat, apart from the Engine lying on its side in the Passat by about 30 degrees, where I fit it in the upright position in the Jeep. The included angle of the AV mounts is about 45 degrees in the Passat, which I maintained in my mount arrangement. The chassis brackets are made out of 100 x 100 x 5 mm box section, like this:
The engine brackets were made out of 5mm plate, like this:
All mounted, it looks like this, RH side:
LH side:
Engine looks at home in the chassis:
Thanks for reading!
Daan
  • Like 3
LH side:
Thanks for reading!
Daan
Just shout if I can help you with materials ( still have 28m of 6" x1/ 4" flat bar ) regards Stephen
  • Like 1
2 hours ago, Anderzander said:
Excellent news !!
How’s clearance at the front of the engine in its new position ?
I bet it will be a little rocket with that 1.9 in there.
Loads of space in that area, but less in others...
The Passat B5 with this engine does 122MPH according to the specs, and is 100 kg heavier compared to the Jeep.
I am planning on fitting a block of wood under the throttle!
  • Haha 1
