Alpine window hole cutting help
Hi
I've got some alpine windows that I intent to install in my none alpine window roof. I'm after some help with the hole location from the back edge does anybody have the dimensions or where I can find a cutting guide? Also it's a puma and I'll be installing the headlining not sure if they are in same place on earlier models?
Cheers
Tom
I have the alpine windows out of my 1991 110 CSW  and the front of the cut out is 38" measured from the front end of the rain gutter above the corner of the windscreen.  Alternatively, the rear of the cut out is 39.5" measured from the rear of the roof.  Hope this helps.
Mike
