Sign in to follow this
bongo321
intake manifold thread size
Hi does anyone know the thread size in the intake manifold at the rear on a defender 300tdi . To take a boost gauge feed .
Share this post
Link to post
Hi,
I did this exact addition myself a few years ago.  I bought, I can't remember where from, perhaps ebay, a banjo fitting with a bayonet connection, see photo.  I've just measured it and it's a 12x1.5 metric fitting.  HTH.
Mike
Share this post
Link to post
Couldn't tell you the threads, I just found something that fitted....but.....while your at it....
What you should do is plumb the waste gate to that connection and plug the port at the turbo....that gives you 1 bar of boost at that end of the inlet manifold before the waste gate opens rather than 1 bar at the turbo :)
Share this post
Link to post
Posted (edited)
Agreed.  I've also done that.  But I believe that the waste gate starts opening at about 9 - 10 psi boost, and is fully open at 15psi.  I haven't worked out yet how to delay the opening of the waste gate without raising the final boost pressure.  Perhaps a grown up can cover that mod.
Mike
Edited by Troll Hunter
Additional comment inserted.
Share this post
Link to post
Posted (edited)
Heard about this but wasn't to sure about it  , So you would advise doing it .  , the Plenum thread is as Troll Hunter said 12x1.5 .
Edited by bongo321
Share this post
Link to post
Dont know if it makes a difference....the theory suggests it would.  I did it and a few fuel pump tweeks to my last 300tdi before I put it on the road so dont know what it would have been like before I fiddled with it ....maybe better :)
Dont know about that.  I had a boost gauge and it went straight to just over 1bar no bother.  But again I suppose if the waste gate didnt start to move until 1bar you;d have a few seconds more of full pressure.
I do have a turbosmart boost controller that I never fitted to the last one....I'll have to dig it out once I get this 300tdi on the road :)
Share this post
Link to post
Wasn't there some issue of the turbo running away ?? . it was some danger of something going pop .
Share this post
Link to post
