JRC93 Posted January 9, 2019 Share Posted January 9, 2019 Hi there, New to this forum so be gentle! I’m looking for some advice about my 04 Defender 90 Td5 - I get a metallic scraping scratching noise at about 30mph when I’m setting off - seems to be coming from left hand side fwd wheel but can’t place any closer than that! I’ve checked for rubbing on the wheel, and had a root around behind it but have yet to see any cause. My next thought is whether the wheel bearing is worn which I’m going to check this weekend when I’ve got time (hopefully!) but was wondering if anyone out there has had a similar problem or knows what else it could be? Thanks! Quote Link to comment Share on other sites More sharing options...
Landrovernuts Posted January 10, 2019 Share Posted January 10, 2019 Try a stone or something else caught between the shield and the brake disc. Toby Quote Link to comment Share on other sites More sharing options...
JRC93 Posted January 10, 2019 Author Share Posted January 10, 2019 38 minutes ago, Landrovernuts said: Try a stone or something else caught between the shield and the brake disc. Toby Would that mean the noise would be present all the time if it were the case? I’ll have a closer look but the noise seems to go once the car has warmed up? Quote Link to comment Share on other sites More sharing options...
Lightning Posted January 10, 2019 Share Posted January 10, 2019 As above, take the wheel off and have a look. Be aware that the handbrake is not like a car, it works on the transmission, so if you apply the handbrake then lift one wheel the vehicle can roll. Be sure to chock one of the other wheels. Quote Link to comment Share on other sites More sharing options...
JRC93 Posted January 13, 2019 Author Share Posted January 13, 2019 On 1/10/2019 at 8:28 AM, Lightning said: As above, take the wheel off and have a look. Be aware that the handbrake is not like a car, it works on the transmission, so if you apply the handbrake then lift one wheel the vehicle can roll. Be sure to chock one of the other wheels. So I took both front wheels off and checked between the shield and discs, nothing between them, but one of the shields was bent onto the disc - however I bent it back into position and the noise is still persisting! Is there any other common problem that it may be? Quote Link to comment Share on other sites More sharing options...
