western
Flip up screen stereo/cd
Thinking about replacing the current Visteon cd/radio it's the same as in 2008 defenders,  sometimes the cd scanning jumps. otherwise the unit works ok,  thinking about something like this with sat nav capability.
I have the original type dash with the existing unit in the grey plastic single DIN moulding with a 25mm wide spacer ring to make it look tidy,
wondering if the unit or similar pictured will fit & if the screen would sit correctly.
Do any of you have such a unit in their Defender ?
Share this post
Link to post
Not sure the mechanism would last very long if you offroad much etc?
How much do you want to spend?
I'm building a tablet based system, much better for Satnav using a nice tablet screen compared to these types of screens etc, easy to remove overnight etc etc, can advise around your budget if that sounds interesting etc
I was going to use a android head unit like that one (removable screen rather than flip out, but found it horrible to use, screen low quality, lots of mistouching etc)
Edited by roamingyak
Share this post
Link to post
I want to retain the CD/Radio as well, I can use my notebook  running memerymap for off road use which isn't very often & the rammount tray is a bit bulky.
Share this post
Link to post
We have looked Pioneer with the movable screen and found that you can "learn" them to what position they need to go for your specific dashboard. But I have to say I was not impressed with the sturdieness (??) of the various units. The 110 is now running on an iPad for navigation and it works well. There are some options for the CD / Radio to make them "talk" to the iPad / Androids if you want.
Although I've always had Garmin, I am getting less and less impressed with the bigger screen units to work with and running things like Xmotion on the iPad are really nice once you get used to it.
I have destroyed too many CD players over the years to use them. In the Hybrid I have a Kenwood MiniDisk player but that is going to be replaced aswell - getting old...
Share this post
Link to post
I'l leave you to it then...
A few thoughts for others - my entire 500+ cd collection fits on a SDHC card less than 1 inch squared and you can listen to any radio station via the net if you've got a tiny amount of data that you can use - except if in places with no signal.
I made a mount for my ipad using thin 2 * 2cm wide Aluminium strips, put it on top of dash, fold down over the corning, fold underneath the dash bottom again, then some 3 sided strips horizontally to hold it in - point being it sits almost flush against the dash. And that was version 1 done in 30 mines in the dark for departure the next day.
Share this post
Link to post
by retaining the cd/radio I meant I still want that capability, if I decided to change the existing unit for a flip screen item or it'll just be a normal single DIn unit to fit were the existing unit is.
Share this post
Link to post
just to end this, got one of the units in the first post, all working, even managed to get the satnav part working, just need to tidy up the install, need a wider spacer so the screen doesn't touch the dash.
Share this post
Link to post
Have you got any pics of this? Very intrigued by the prospect of installing an Android tablet in the dash as it'll undoubtedly be cheaper and more functional than a normal double-din unit. How do you get it to play through the speakers?
Share this post
Link to post
Making a tablet play through speakers is just a case of fitting a small (2x25W in a SWB defender) car audio amp behind the dashboard somewhere and plugging it into the headphone jack port on the tablet.
Share this post
Link to post
Which unit and from where, please?
Share this post
Link to post
I was pondering a double-din one with no CD mechanism ("mechless") as those look like they'd fit nicely in a centre console and have no moving parts. Also quite cheap these days - there's units out there for sub-£50 :blink:
Just annoying me that very few have built-in DAB, you have to spend quite a lot more or buy extra gubbins :glare: but I guess just using iPlayer on your phone and the AUX input would suffice a lot of the time.
Share this post
Link to post
That looks mint Ralph , I spent quite a bit on a Pioneer unit for the 110 that has dab with a windscreen mounted aerial and its next to useless soon as I go out of the area I live I loose signal , need to read the destructions and work out if I can sort it .
Share this post
Link to post
I don’t think the sound quality matters that much does it in a 200/300 tdi  :rofl: . But I get what you mean , I think you can get better value for money on some of these units than the big names .
Share this post
Link to post
There is a limit though - the £12 head unit we fitted in the ambulance has a very audible background hiss / whine, granted you wouldn't hear it with the engine running in a TDi but it's very noticeable if you use it while parked up.
Share this post
Link to post
Quite true there is a limit to how bad is acceptable , don’t know what’s going on here but I received the usual email notification that someone had posted in this thread , which was western 2 posts one had a photo of the unit he’s installed working but it’s not come up in this thread , strange .
Share this post
Link to post
That's cos it was taking to long to load asthe pics were a bit to large & I deleted it & I needed to leave to drive to work, now today's work is done & I'm home, here are the pics I took earlier. couldn't do anything about the reflections.
as it sticks out a bit so screen can clear the garmin unit, I'm going to get one of the Mudstuff centre consoles https://www.mudstuff.co.uk/products/mud-stuff/mud-defender-console.html & will have to adjust the garmins position.
Share this post
Link to post
Just finished myself Ralph , I hate the afternoon shift . That looks the business  , what’s the sound like good , reasonable? Raptor engineering do some nice dash consoles as well.
Share this post
Link to post
I fitted 4 pioneer g-1010 [IIRC] speakers years ago, sound is good, 2 speaker in factory dash space & 2 in rear headliner, it blast out my Sky cd's with no problem, not overly keen on the raptor centre panel,but may have a look.
Share this post
Link to post
Looks cracking Ralph, very nice indeed :)
  • Like 1
Share this post
Link to post
More of a Smiths man myself , got pioneer speakers in the 110 sounds very good shall be fitting some in the 90 with one of those head units by the look of it .
  • Like 1
Share this post
Link to post
Ralph - are you still happy with this a few days on? I have a flip out unit that has died after a good few years use and want to change it
Share this post
Link to post
