Green200tdi Posted September 3, 2019 Author Share Posted September 3, 2019 9 hours ago, western said: Reckon that will do the job fine Cool 😎 Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted September 6, 2019 Author Share Posted September 6, 2019 So my made up glow plugs 6 pin relay does this, cool 😎 52C50FCB-66A0-4F68-B0ED-8805E135A84C.MOV Quote Link to comment Share on other sites More sharing options...
western Posted September 7, 2019 Share Posted September 7, 2019 That works then 🤗 Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted September 7, 2019 Author Share Posted September 7, 2019 Yeah great, cost of it? Land Rover timer glow plug relay 6 pins part number prc6913 second hand £10 heavy 70 amp cable was £12,50 from td5 under Seat fuse box to relay then relay to glow plugs few spade connectors £5 happy days ralph might be good idea edit this and put in my main post thank you 😊 1 Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted September 11, 2019 Author Share Posted September 11, 2019 So the timer relay was not working for the glow plugs, so the guy I got it off on eBay sent me out not one but two to make sure I was looked after 😊 and yes we are up and running glow plugs for the winter like the 200 tdi needs them but safe to sure but noticed that the dash lights is only on for a little over 3 seconds but you can hear the relay click off around 8 seconds so all is well 00EACFD1-E17F-4191-A75E-3FB06847EF4A.MOV 1 Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted September 11, 2019 Author Share Posted September 11, 2019 On 9/7/2019 at 5:50 AM, western said: That works then 🤗 Oh yes proud of my self 👍 but all thanks to you guys 😊 1 Quote Link to comment Share on other sites More sharing options...
Maverik Posted September 30, 2019 Share Posted September 30, 2019 A very good effort, now I've just acquired 2x TD5 bulkhead looms... would you do a loom conversion again? Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted September 30, 2019 Share Posted September 30, 2019 Mav, I'm using TD5 wiring in my 200, I would absolutely do it again. Bear in mind that I found it best to grab the 2 wing harnesses and rear harness to make it plug and play. Better connectors, newer wiring, better management of branch connecting using headers, econoseal connections for lights have all convinced me that I did the right thing 10 years ago. HTH Mo Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted October 2, 2019 Author Share Posted October 2, 2019 On 9/30/2019 at 9:07 AM, Maverik said: A very good effort, now I've just acquired 2x TD5 bulkhead looms... would you do a loom conversion again? Yes really easy now I have all the answers i need 👍 Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted January 3, 2020 Author Share Posted January 3, 2020 So today I’ve finished the loom every thing in place, water temp sensor cut and taken a wire from the ecu multi plug stright to temp sensor, reverse lights, transfer box warning lights on dash, and speedo Most from the grey multi plug under the bonnet by the orange multi plug, so if like me was looking for the transducer signal wire it’s the BLACK /RED TRACER, have bridged the black/red tracer with the purple (permanent live) wire to make sure it’s live and connected to the right wire on the other side of the multi plug, yes I screwed up and was one wire out😂 but got there in the end 👍 Quote Link to comment Share on other sites More sharing options...
