PaulMc Posted January 10, 2019 Share Posted January 10, 2019 (edited) C0195 is a 3-way female Econoseal III 070 connector - It's wired as follows - Terminal 1 - White/Green - Ignition-switched live, from fuse 12 (10A) in the bulkhead fuse box Terminal 2 - Black - Earth, to header C0550 (earth stud on bulkhead in engine compartment) Terminal 3 - Black/Red - Signal, to speedo Pink ISO connector (C1060) The wiring for these is already in your main harness (from connector C0448), and would normally go through connector C0162 on the engine harness, that mates with C0448 on the main harness. In C0448 (and C0162) the wires are on the following terminals - White/Green - Terminal 12 Black - Terminal 6 Black/Red - Terminal 10 I can supply the Sumitomo 14-way male connector (C0162), if you wanted to make your own engine harness? . Edited January 10, 2019 by PaulMc Quote Link to comment Share on other sites More sharing options...
Scotts90 Posted January 11, 2019 Share Posted January 11, 2019 20 hours ago, roverv8 said: Ok anyone recognize these these 3 plugs?🤔 gray multi plug and green are alarm? and the one below is for the throttle peddle? am i right? Yes to both Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted January 11, 2019 Author Share Posted January 11, 2019 (edited) I’m getting good eh? 😂 thanks to you guys 👍 paulmc you have pm. Edited January 12, 2019 by roverv8 Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted January 13, 2019 Author Share Posted January 13, 2019 Just a quick question, which plug goes to rear light and what one goes to engine electrics? Just need to get this sorted so can be sure when I order male connectors, Thank you 😊 Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted January 14, 2019 Share Posted January 14, 2019 They are normally keyed so you can't get it wrong. By going on a hunch, the oily mucky one is for the engine and the clean grey one for lights Quote Link to comment Share on other sites More sharing options...
western Posted January 14, 2019 Share Posted January 14, 2019 Wire colour code should ident the plug for rear lights, the code stayed the same. Thought you were going to put all these td5 loom questions into the one thread. I can merge this if you want me to Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted January 14, 2019 Author Share Posted January 14, 2019 though id ask as just a quick open to all other people may not go in to my original thread, BOWIE i agree with what you say as one is 10 pin and the other is 14 pin going on the 14 pin id say thats my rear lights rear wiper rear heated screen and so on, problem i have is im only fitting the main loom at the moment im not doing the rear lights yet so say the orange plug is my rear lights i can get the male plug and make up an adapter from old to new, this way come new rear loom time its just a case of plug in and water tight (thats the idea anyway)😂 ralph yes please if you can Quote Link to comment Share on other sites More sharing options...
western Posted January 14, 2019 Share Posted January 14, 2019 Done Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted January 14, 2019 Author Share Posted January 14, 2019 (edited) ok people what color is the head lights relay? put a live and earth on my under seat fuse box new switch got side lights but no head lights checked ALL fuses nothing also do the head lights go off when you turn off the ignition? been doing a bit o detective work and worked out that the orange plug id defo rear lights, Edited January 14, 2019 by roverv8 Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted January 14, 2019 Author Share Posted January 14, 2019 Ok update amazed my self here but lights are now working,😳 helps to earth out grey box that fits to under bonnet bulk head, put an earth to the head light bulb it self and the interior light come on🤔 so bit more digging around I just thought the grey box was a wire connector for all the earths didn’t think for a second it was THE earth 😂 so must be bolted in place or nothing will work😉 EEBCFC7E-1A33-4732-90CA-5966F73EDA9D.MOV Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted January 14, 2019 Share Posted January 14, 2019 That'll do it... Quote Link to comment Share on other sites More sharing options...
western Posted January 14, 2019 Share Posted January 14, 2019 making progress. Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted January 14, 2019 Author Share Posted January 14, 2019 33 minutes ago, western said: making progress. I like progress 😂 i want it all working when I put it in the landy nothing more annoying then once it’s fitted but it won’t work that means the whole car is off the road so just a case of engine wires to sort, rear lights and speedo and were sorted😊 1 Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted January 15, 2019 Author Share Posted January 15, 2019 (edited) So horn turned up today that’s working, have main beam flasher but still have no dip beam or main beam when indicator stalk pushed forward to main beam on Is there any more of these on the td5 loom? See pic, Earth update now have n/s head light and dim beam woo hoo and head lights go thu ignition switch which is great news no more having to switch off head lights at the shops lol Edited January 15, 2019 by roverv8 Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted January 15, 2019 Author Share Posted January 15, 2019 (edited) sorry was unable to edit update, So horn turned up today that’s working, now have both head lights lights go thu ignition switch which is great news no more having to switch off head lights at the shops lol right now have dim dip both sides, dip beam both sides, main beam both sides, head light flasher both sides, dodgy earth and duff bulb all good now Edited January 15, 2019 by roverv8 1 Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted January 15, 2019 Author Share Posted January 15, 2019 no indicators due to no hazard light switch,🙄 anyone got a spare old td5 switch knocking about??? Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted January 17, 2019 Author Share Posted January 17, 2019 well so far so good ive got rid of the bmw connector and upgraded the stereo plugs with a more modern type and the front speaker wire was well next to usless very thin, gone for the silver/gold clear cable got to be better then what was in there, every thing works all except indicators Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted January 22, 2019 Author Share Posted January 22, 2019 Do you need the alarm ecu on the td5 loom to make the interior light work on the door plungers? it does work on its switch on the light it’s self Quote Link to comment Share on other sites More sharing options...
Scotts90 Posted January 22, 2019 Share Posted January 22, 2019 Yes, it needs the AS10 unit installed (and the interior light activated using a suitable diagnostic tool) Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted January 23, 2019 Author Share Posted January 23, 2019 Thank you. 😊 so todays top tip if your going to change your broken hazard light switch for another in your td5 and the price is stupid go for a Rover 25 switch ok so the triangle maybe wrong way round but at £4,99 I’m not complaining 😂 Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted January 23, 2019 Share Posted January 23, 2019 22 hours ago, roverv8 said: Do you need the alarm ecu on the td5 loom to make the interior light work on the door plungers? it does work on its switch on the light it’s self I'd wager that if you don't want the 10AS installed, then you can just ground the wire the ECU would normally control by extending it as necessary to reach the door pin switches. Which pin that is I am not sure, but you can probably trace the wires back to the 10AS unit using the colours seen at the dome light. Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted January 23, 2019 Author Share Posted January 23, 2019 If all goes to plan I’ll see if I can get a cheep 10AS see if I can get an alarm up and running as I have central locking Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted January 24, 2019 Author Share Posted January 24, 2019 I love going on eBay and finding the little bargains, so this is today’s little bargain two td5 side repeater lamps £3,50 😊 Quote Link to comment Share on other sites More sharing options...
Scotts90 Posted January 24, 2019 Share Posted January 24, 2019 If you get busy with some card and a ruler you can knock up a template so they clip in factory style.... Worked out fine on my 200 wings. 1 Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted January 28, 2019 Author Share Posted January 28, 2019 Thank you 😊 Quote Link to comment Share on other sites More sharing options...
