Green200tdi Posted January 29, 2019 Author Share Posted January 29, 2019 So these arived today my little bargain and a 10AS with fob is on its way too😊 Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted January 30, 2019 Author Share Posted January 30, 2019 Does the td5 defender have a two pump window washer bottle? Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted January 30, 2019 Share Posted January 30, 2019 It can have. Mo Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted January 30, 2019 Author Share Posted January 30, 2019 Red plug and black plug??? Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted January 30, 2019 Author Share Posted January 30, 2019 When the 10AS is plugged in should it work straight away flash the indicators? Quote Link to comment Share on other sites More sharing options...
Scotts90 Posted January 31, 2019 Share Posted January 31, 2019 Should do, not all 10AS are configured the same way though. Mine has full activation for immobiliser, interior sensors, pin switches and central locking. Depends on what spec of vehicle the unit came from, some don't have the internal relay for the locking but this can be retrofitted. Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted January 31, 2019 Author Share Posted January 31, 2019 It said in full working order when I got it, as I’m just plugged in to a loom hanging on the wall I though it would least flash the indicators no red light on the fob to see if working could be the battery in fob Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted January 31, 2019 Author Share Posted January 31, 2019 What are these two relays for in the seat box with main ECU Yellow Black 😊 Quote Link to comment Share on other sites More sharing options...
Scotts90 Posted January 31, 2019 Share Posted January 31, 2019 The fob doesn't have a red light, just two buttons. Do you have the td5 clocks? These have the alarm indicator led built into the speedo so would show what it's doing. This won't be an easy thing to bench test as it reads inputs for the pin switches (doors and bonnet) and will signal a circuit fault. It doesn't need the power sounder fitted as it will activate the horn. Quote Link to comment Share on other sites More sharing options...
Scotts90 Posted January 31, 2019 Share Posted January 31, 2019 without seeing the wire feeds... yellow main ignition relay or cooling fan black either ABS or glow plug depends on loom Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted January 31, 2019 Author Share Posted January 31, 2019 I’m sure it will sort it’s self when I fit it to the 110 like I said not really important atm I’ve got no ignition at mo so could have something to do with it, i have td5 clocks but there in use in the 110 at present any idea on the relays under seat ? See photo think the brown relay on the main fuse panel is the alarm the more questions I ask the better for when I come to fit the loom 😊 Quote Link to comment Share on other sites More sharing options...
Scotts90 Posted January 31, 2019 Share Posted January 31, 2019 4 hours ago, Scotts90 said: without seeing the wire feeds... yellow main ignition relay or cooling fan black either ABS or glow plug depends on loom As above for the under seat relays. And yes, the brown one on the main fuse panel does the alarm/sounder Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted January 31, 2019 Author Share Posted January 31, 2019 2 hours ago, Scotts90 said: As above for the under seat relays. And yes, the brown one on the main fuse panel does the alarm/sounder 2005 15p loom Quote Link to comment Share on other sites More sharing options...
Scotts90 Posted January 31, 2019 Share Posted January 31, 2019 Not just that simple, if you have the bulkhead loom part number it will tell you the spec of the vehicle it came from. There are numerous permutations, from basic to fully loaded XS spec. Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted February 1, 2019 Author Share Posted February 1, 2019 Ok thank you I’m sure it will sort it self when I fit it 👍 Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted February 2, 2019 Author Share Posted February 2, 2019 Are the loom connectors coloured for a reason like orange for rear lights and grey for engine loom or do they work on PIN numbers colour nothing to do with it? Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted February 3, 2019 Author Share Posted February 3, 2019 When it starts to come together and you start to feel happy with your idea and purchases 😊👍 min all the time I’ve had this td5 dash never seen the alarm light working guess my 10AS is fine 🥳 97E25403-7E17-44DF-A2A7-244F5E367703.MOV Quote Link to comment Share on other sites More sharing options...
Scotts90 Posted February 5, 2019 Share Posted February 5, 2019 Nicely done. FYI the reason the LED is “solid” and not flashing is down to the alarm thinking the doors are open (pin switches) if you have the immobiliser activated (as indicated on the dash panel) then you’ll need the pick up ring for around the ignition barrel so that the fob can disable the immobiliser when in close enough proximity. With regards to the plugs above, they are different pin/plug arrangements so won’t interchange as the guide slots are in different orientations iirc...making them different colours just makes it easier to identify. Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted February 8, 2019 Author Share Posted February 8, 2019 Cool thank you as they say every little bit of info helps,😂 ordered my TD5 ignition barrel today it’s coming along roll on summer👍 ok any idea what this plug is for it’s on the same part of loom as the rear fog light switch? Quote Link to comment Share on other sites More sharing options...
PaulMc Posted February 8, 2019 Share Posted February 8, 2019 It's for the headlamp levelling switch. Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted February 9, 2019 Author Share Posted February 9, 2019 18 hours ago, PaulMc said: It's for the headlamp levelling switch. Thank you you have pm btw 🤔😂 Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted February 12, 2019 Author Share Posted February 12, 2019 So I got busy today, starting to take shape now bit of warm weather can’t wait to get new loom in 😊 2 Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted February 13, 2019 Author Share Posted February 13, 2019 (edited) Quick question front indicator light plug, Are these clips soposed to come out the plug when you remove the lamp? Edited February 13, 2019 by roverv8 Quote Link to comment Share on other sites More sharing options...
simonb Posted February 13, 2019 Share Posted February 13, 2019 No, they are supposed to retain the contacts in the connector. In your 2nd image, it looks discoloured from overheating. Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted February 13, 2019 Author Share Posted February 13, 2019 (edited) Interesting, now I’ve eather got a cheep set of light connectors as both bulbs holders have melted and bulbs gone sideways and turned them self off or there’s a loom problem 🤔 Edited February 13, 2019 by roverv8 Quote Link to comment Share on other sites More sharing options...
