Gazzar Posted January 21, 2019 Share Posted January 21, 2019 I'm experimenting with an idea. Do you have easy access to a late series LWB fuel sender? The one with the fuel pipe built-in? Could you measure the diameter of the mounting plate? Don't go out in the cold to do it, I've one in the pickup, and I'm too lazy to go out in the sleet, and free up the screws holding the access plate down. I'm trying to see if I could add an in-tank pump for an EFI conversion for my lightweight project. Thanks. Quote Link to comment Share on other sites More sharing options...
Gazzar Posted January 26, 2019 Author Share Posted January 26, 2019 In a fit of bravery, I ventured outside. The diameter is 65mm, I'd preferred it to be 70. But I think it will work, even if I have to sandwich the LWB sender in place. Quote Link to comment Share on other sites More sharing options...
