CarlBrit Posted January 23, 2019 Share Posted January 23, 2019 Hi All, Just purchased a Freelander TD4 GS 2002, the near side front window does not work at all, Im getting no noise from the relay or motor. So, after checking the window switch and fuse (F33) I put a meter across the fuse contacts and found there to be no power feed at all. Please can anyone give me any ideas as to whats going on !! Regards Carl Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted January 23, 2019 Share Posted January 23, 2019 Per your other thread (horn stuck on) I wonder if there's some larger electrical issue with your vehicle. You may find there's a bigger fuse (EG engine bay box) feeding into the electric window circuit, I'd chase the path from battery using the circuit diagrams in the RAVE manual. Quote Link to comment Share on other sites More sharing options...
CarlBrit Posted January 28, 2019 Author Share Posted January 28, 2019 Update on this. Went to a scrappy on Saturday morning, purchased a rotary coupler and Steering wheel for £30 and horn now works, hurrayyy. Quote Link to comment Share on other sites More sharing options...
abbo66 Posted January 7, 2021 Share Posted January 7, 2021 bought a 2000 landy and the windows were not working the passenger side requires a new cable but the drivers window was simply the plug had come apart in the door this may be helpful to you allan Quote Link to comment Share on other sites More sharing options...
