Chubby M Posted January 31, 2019 Share Posted January 31, 2019 Good afternoon and happy New Year all from a forum newbie.... Question (risking it being a silly one). My 1985 110 front axle is truly shot - corroded beyond repair and I'm unable to break it down for refurb. Simple (?) - replace with a salvaged 110 front axle. Id like to replace with as new a unit as possible (2011 PUMA on auction site for example) to ensure swivels / calipers etc. are in decent order - but, these "newer" axles often have ABS. The question: Can I swap out the 1985 for a newer ABS carrying unit and somehow "disable" or bypass the ABS - as there will be no wiring / sensor feeds etc. for it??? Huge thanks in anticipation, Chubby M Quote Link to comment Share on other sites More sharing options...
western Posted January 31, 2019 Share Posted January 31, 2019 Yes, just remove the abs sensors from the swivels on the new axle Quote Link to comment Share on other sites More sharing options...
neil110 Posted January 31, 2019 Share Posted January 31, 2019 Another thing to bear in mind is that the Bush sizes are bigger on later axles, from memory the change occurred with the introduction of the 300 1 Quote Link to comment Share on other sites More sharing options...
Ex Member Posted January 31, 2019 Share Posted January 31, 2019 What neil means is you need the radius arms and panhard rod as well with the axle. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted January 31, 2019 Share Posted January 31, 2019 If you get an axle from 1994 to 2002 you’ll just need the matching radius arms. If you get an axle from 2002 onwards then you’ll need the above plus a panhard rod and also the bracket that attaches the panhard rod to the chsssis. Plus bolts and replacement bushes as required. Quote Link to comment Share on other sites More sharing options...
Chubby M Posted February 1, 2019 Author Share Posted February 1, 2019 Gentlemen, many thanks for your swift and helpful input. Much appreciated. Quote Link to comment Share on other sites More sharing options...
