nige90 Posted December 23, 2006 Share Posted December 23, 2006 Pulled the motor apart to find severe wear on No1 bore. Local engine shop has quoted £80 each for pistons, but Paddocks website shows them for half that. Does anyone know who manfactures thier stock ? Having read the post recently in the Discovery forum about variable quality from Britpart, I want ensure I get good pistons preferably not spending nearly £400. Nige Quote Link to comment Share on other sites More sharing options...
western Posted December 23, 2006 Share Posted December 23, 2006 Not sure of the piston manufacturers, but EPC [2002 prices excluding vat] 200Tdi piston kits [full set 4 pistons] standard 'X' ERR1390 £246.33 standard 'Y' ERR1391 £165.32 0.020inch oversize STC1052020 £231.29 0.040inch oversize STC1052040 same as 0.20inch oversize. Quote Link to comment Share on other sites More sharing options...
SiWhite Posted December 24, 2006 Share Posted December 24, 2006 Whereabouts are you Nige? There's a great engine reconditioners close to Oxford who supplied mine. Not sure on price but reasonable IIRC. Let me know if you need more details. Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted December 24, 2006 Share Posted December 24, 2006 Pulled the motor apart to find severe wear on No1 bore.Local engine shop has quoted £80 each for pistons, but Paddocks website shows them for half that. I want ensure I get good pistons preferably not spending nearly £400. Nige If they turn out to be quality branded that would be a bl@@dy good price at £40?? ea. When i replaced mine 2 years ago, they were i think Hepolite, @ £60 ea trade & no VAT, so £80ea is probably right now. Cheap pistons will be suspect material probably with a high expansion & made in China, rather than the correct low expansion so will rattle well when cold, possibly with cracking issues & causing bore cracking from the piston slap as well so best avoided. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted December 25, 2006 Share Posted December 25, 2006 Buy the pistons yourself - Garages etc make a profit on parts as well as labour, so it's more than reasonable to think you might get the pistons cheaper if you buy them yourself. I paid about £40 each for TD pistons, and they are Hepolite. You should get a piston kit, which is Piston, rings, piston pin (gudgeon pin) and circlips. When you say severe wear on No1 bore, do you know why just the one bore is bad? Les. Quote Link to comment Share on other sites More sharing options...
nige90 Posted December 26, 2006 Author Share Posted December 26, 2006 Whereabouts are you Nige?There's a great engine reconditioners close to Oxford who supplied mine. Not sure on price but reasonable IIRC. Let me know if you need more details. Oop North on the Wirral Si. Shopping around for prices at the mo, or will be once the shops open again. Les, haven't found a reason for just the one bore yet, suspecting a blockage in the oil squirter thing that feeds the skirt but not stripped them out yet. The piston itself is hardly marked and the concentric machine marks are still intact right round the skirt. Rings intact but visibly radiused. Hoping a 40thou bore will sort it or I'll be back on looking for a block The engine ran fine apart from a reasonable amount of fuming from the rocker box and a slight slap on gentle over-run. Been on Turner Eng's site, similar price tp Paddocks. Anyone experienced Turners ? Nige Quote Link to comment Share on other sites More sharing options...
western Posted December 26, 2006 Share Posted December 26, 2006 I've no direct experience of Turners but will say that Richard knows his LR engines & only produces quaility kit. Turners Quote Link to comment Share on other sites More sharing options...
Les Henson Posted December 26, 2006 Share Posted December 26, 2006 Never heard a bad word about Turner Engineering. I would recommend them on their reputation alone. Les. Quote Link to comment Share on other sites More sharing options...
sadoldgit Posted December 27, 2006 Share Posted December 27, 2006 If they turn out to be quality branded that would be a bl@@dy good price at £40?? ea. When i replaced mine 2 years ago, they were i think Hepolite, @ £60 ea trade & no VAT, so £80ea is probably right now. Cheap pistons will be suspect material probably with a high expansion & made in China, rather than the correct low expansion so will rattle well when cold, possibly with cracking issues & causing bore cracking from the piston slap as well so best avoided. you're dead right phill there are some carp pistons out there. we fitted 5 to a 6 cylinder lister, the engineer doing the job refused to fit them at first but there was some issue with supply. so he did it reluctantly. they lasted 3 months, one of them was a melted lump on the end of the con rod the other 4 looked like they had done 10 000 hours and the one genuine piston was still like new but i'm sure any reputable firm would only fit good uns, and i'd steer clear of buying anything so critical in a britpart box (if indeed they supply pistons) good luck paul Quote Link to comment Share on other sites More sharing options...
mike4444244 Posted December 28, 2006 Share Posted December 28, 2006 Hi Try Newtons engineering on south st in Lpool, i have had engine parts from them before and they have always been helpful with good advice etc. Mike Quote Link to comment Share on other sites More sharing options...
selectcase Posted December 30, 2006 Share Posted December 30, 2006 There is a company on ebay who supply bankrupt stock pistons I got a set of genuine AE +40 for a 200tdi for £65 all in incl gudgeon pins and circlips worth a try Quote Link to comment Share on other sites More sharing options...
