russelldavis Posted February 6, 2019 Share Posted February 6, 2019 Hi, I have a 1997 300tdi. The brake warning light is not coming on at startup (the test it does). The low level switch is working but the hand brake switch isn't, I am not sure if that's connected to the fact the start up test is not happening. I know it's not the end of the world but would like to see if I can fix it. Any ideas of where to start? Is there a relay for this lamp flashing at startup? Thanks! Quote Link to comment Share on other sites More sharing options...
ballcock Posted February 6, 2019 Share Posted February 6, 2019 Welcome to the forum. I don't know whether it should on start up as it has a test facility. I would be more concerned that the hand brake lever is not operating it, I would check that the lead is connected and the switch makes contact to earth. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted February 7, 2019 Share Posted February 7, 2019 (edited) 300TDI era trucks do not have a brake light check function. Earlier trucks did have a check relay. Both the low level switch and the park brake switch are directly connected to the lights. The switches switch to ground. Edited February 7, 2019 by Red90 Quote Link to comment Share on other sites More sharing options...
Ex Member Posted February 7, 2019 Share Posted February 7, 2019 (edited) Here is a link to the wiring diagram. Page 47.1 http://duud.ee/LR-manualid/300Tdi_Wiring_Diagrams.pdf Edited February 7, 2019 by Red90 Quote Link to comment Share on other sites More sharing options...
