Sign in to follow this
ibexman
Td5 LT 230 cable operated
Just fitted new dashboard and want to convert lt 230 to cable operation  has anyone attempted this with D2 cables or  otherwise cheers Chris
Share this post
Link to post
I converted mine, the gearbox pushed it further back than normal so the mechanical link would have been difficult to relocate, especially the diff lock.
The diff lock is simple enough as it uses the same connection as the mechanical link and I don't remember having any issues with it. The hi/lo is a completely different lever at the transfer box end though and posed more of an issue. i can't remember the exact details as it's about 12 years since I did mine but ISTR that the lever is incompatible and the cable won't connect to it properly without some fettling. I was lucky as, having failed to remove the old lever to make a new one, I lucked across a broken cable selected transfer box and swapped the whole hi-lo lever assembly over.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
