petrolhead63 Posted February 11, 2019 Share Posted February 11, 2019 (edited) I have a perfect set of four window glass seals (outer) for the discovery to replace the bubbled originals which are grim now. how do I remove/replace these? I have done plenty of old cars with clips using a tool fabricated to pull the clips upwards without removing door cards etc but do not know how the disco ones are fitted. Many thanks. Edited February 11, 2019 by petrolhead63 Quote Link to comment Share on other sites More sharing options...
bear Posted February 16, 2019 Share Posted February 16, 2019 Hi, Took some pictures today whilst replacing my f/o/s window regulator. They show the clips holding the inner section of the trim on and then should just pull off. HTH, Griff Quote Link to comment Share on other sites More sharing options...
petrolhead63 Posted February 25, 2019 Author Share Posted February 25, 2019 Thanks for that, very much appreciated. I can do the first one when I fix the front n/s window regulator! other than the pain of removing the door cards its easy enough for the other three! shame...old cars often could be done without removing door cards very often by carefully using a tool to pull clips up.. Quote Link to comment Share on other sites More sharing options...
