Defender 90 chassis
Hi I have a 200tdi engine that I want to put in a puma body I just wondered is it possible to do this as the engine mounts are different and I’m not sure if I can fabricate engine mounts onto the chassis or if this is not possible. Could anyone shed any light, Thanks
Edited by Harry defender
It would be a lot easier to fit another puma. Assuming you still have the gearbox you'll need an adapter (I believe it's been do for a 300tdi). Your dash may not work and half the engine wiring will need altering. Exhaust and gearing will probably need looking at. Engine mounts will be comparatively easy to sort.
Mike
  • Like 1
