dred90 Posted December 24, 2006 Share Posted December 24, 2006 I'm currently running a set of 255/85/16 BFG mud's on mach 5 wheels, couple of them have suffered sidewall damage from offroading, one of them is still tubeless and beginning to leak. Obviously if i whack a tube in there this will fix the problem, but it got me thinking - should I really look at replacing the whole tyre bearing in mind I occasionally have to travel long distance at motorway speeds, putting a lot of stress on the tyre. Would like to keep using the tyre if I can as theres loads of tread on it. What's the best thing to do?? Quote Link to comment Share on other sites More sharing options...
rtbarton Posted December 24, 2006 Share Posted December 24, 2006 I'm currently running a set of 255/85/16 BFG mud's on mach 5 wheels, couple of them have suffered sidewall damage from offroading, one of them is still tubeless and beginning to leak. Obviously if i whack a tube in there this will fix the problem, but it got me thinking - should I really look at replacing the whole tyre bearing in mind I occasionally have to travel long distance at motorway speeds, putting a lot of stress on the tyre. Would like to keep using the tyre if I can as theres loads of tread on it. What's the best thing to do?? Replace it. Tubes don't have any strength, they rely on the cover. A weakness in the cover means a weak tyre that could disintegrate. Remove the tyre, slash it so it is obviously damaged to stop an unscrupulous person selling it on to an unsuspecting customer. Quote Link to comment Share on other sites More sharing options...
ciderman Posted December 24, 2006 Share Posted December 24, 2006 Scrap it , Cause you be sure that it will blow out when it gets hot on the motorway and have possibly fatal circumstances . I woulnt even use it as a spare. Quote Link to comment Share on other sites More sharing options...
TJ101 Posted December 24, 2006 Share Posted December 24, 2006 Same tyres/rims as myself,, if ANY visable damage to the cords, bin them, wether tubed or not, Quote Link to comment Share on other sites More sharing options...
Andy Posted December 24, 2006 Share Posted December 24, 2006 bin is the sensible answer, but then my spare has a sidewall puncture sealed with a P40 mixer plate vulcanised to the inside & then tubed. its survived several motorway trips or 3-4hours. not great for safety i know, however ive had a tube pop in a rear tyre doing 65-70mph - all that happened was a clunk as the rim hit the floor & it dragged left a bit. wasnt hard to control when i pulled over to replace it. front could be more interesting though. Quote Link to comment Share on other sites More sharing options...
freeagent Posted December 24, 2006 Share Posted December 24, 2006 bin it, i'm pretty sure you shouldn't realy run tubes in tube-less tyres as a long-term fix anyway, something to do with the inside of the tyres being rough and rubbing on the tube.... m@tt Quote Link to comment Share on other sites More sharing options...
Andy Posted December 24, 2006 Share Posted December 24, 2006 yeah ive heard that Matt, probably explains my puncture. id tubed that tyre as the bead refused to seal for more than a few days after fitting. Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted December 24, 2006 Share Posted December 24, 2006 Scrap it. Don't take chances with safety related items. Quote Link to comment Share on other sites More sharing options...
rtbarton Posted December 24, 2006 Share Posted December 24, 2006 bin it, i'm pretty sure you shouldn't realy run tubes in tube-less tyres as a long-term fix anyway, something to do with the inside of the tyres being rough and rubbing on the tube....m@tt I understand you can get thicker tubes to overcome this Quote Link to comment Share on other sites More sharing options...
nicksmelly Posted December 24, 2006 Share Posted December 24, 2006 Not the PC answer everyone else is giving here, but if the cords are not damaged and it's just rubber thats damaged, i'd take it to a professional vulcaniser and have it repaired. I've had this done to a set of Dirt devils that had some quite severe looking splits in the sidewalls, but no cord damage. They were repaired by proper vulcanising and it only cost £30 for 2 tyres. They are still alive and well on another vehicle with no apparent problems. I know its another risk to take, but i've seen virtually brand new tyres disintergrate on the motor was no reason. This is only my personal opinion. Quote Link to comment Share on other sites More sharing options...
Andy Posted December 24, 2006 Share Posted December 24, 2006 if only i could find a professional vulcaniser, i looked for ages before going for the bodge option on my spare. Quote Link to comment Share on other sites More sharing options...
dred90 Posted December 25, 2006 Author Share Posted December 25, 2006 if only i could find a professional vulcaniser, i looked for ages before going for the bodge option on my spare. Having the same trouble meself, search the net for one and you're more likely to end up at the star trek fan club!! Quote Link to comment Share on other sites More sharing options...
Andy Posted December 25, 2006 Share Posted December 25, 2006 only lead ive got so far is that truck/bus tyres are legal to fix sidewall punctures. if only i was ever in the yard when our tyre man appears i might remember to ask him. Quote Link to comment Share on other sites More sharing options...
Steve King Posted December 26, 2006 Share Posted December 26, 2006 "Bin it "is of course the PC answer as mentioned before by others. It is quite amazing though the repairs that the some of the skilled Turkish tyre repairers (called Lastikçi) can do!! However whether the repair would get you through the British MOT and whether I would actually entrust my life to the repaired tyres is a totally different matter...!!! Steve Quote Link to comment Share on other sites More sharing options...
Les Henson Posted December 27, 2006 Share Posted December 27, 2006 If a tyre has such a deep cut in it that it leaks, then it's beyond help and should be thrown away. The other might be ok to be kept as a spare, or at the very least fitted to the rear or the vehicle, where sudden deflation is less dangerous. MOT specifications are different between new and re-tread tyres. Sidewall damage where the carcass can be seen, but not damaged, is ok within limitations on a retread tyre, as is perishing. but a new tyre will fail on the same thing (or at least it should). It might be worth mentioning that the carcass cannot be repaired. Vulcanising is a repair to the rubber only. Les. Quote Link to comment Share on other sites More sharing options...
GBMUD Posted December 27, 2006 Share Posted December 27, 2006 My BFGs also show damage to the side-walls but they have been checked very thoroughly at the MOT and passed. Cuts into the rubber are a normal part of off-road use and, as long as they are not deep (down to the cords is pretty deep!) they are fine, no worse that bits of tread rubber missing - as said, the strength of the tyre is in the carcass. It is worth checking them very thoroughly and regularly to be sure that there is no potentially dangerous damage, i.e. to the cords that make up the carcass of the tyre. Have a search of the forum for leaking tyre beads on BFGs, it seems pretty popular and is more likely to be the problem with yours. See leaking Matt Lee rims for a potential culprit too. If you want to find your leak, apply a weak solution of washing-up liquid about the tyres, beads and wheel spokes, any leak will show up with a stream of bubbles. Bet you yours is the mud in the bead syndrome. If you decide to junk the tyres, I'll have them for my trailer. Chris Quote Link to comment Share on other sites More sharing options...
nicksmelly Posted December 27, 2006 Share Posted December 27, 2006 I use Rossendale Vulcanising which is near Rawtenstall in Lancashire - Unit 1 Britannia Mill Stoneholme Road, Rossendale, BB4 8BA - 01706220236 Quote Link to comment Share on other sites More sharing options...
dred90 Posted December 27, 2006 Author Share Posted December 27, 2006 Have a search of the forum for leaking tyre beads on BFGs, it seems pretty popular and is more likely to be the problem with yours. See leaking Matt Lee rims for a potential culprit too. If you want to find your leak, apply a weak solution of washing-up liquid about the tyres, beads and wheel spokes, any leak will show up with a stream of bubbles. Bet you yours is the mud in the bead syndrome.If you decide to junk the tyres, I'll have them for my trailer. Chris yes the mach 5's / leaking beads can definitely be a problem with this setup, but this is more a case of 32 psi to 0 psi in less than a mile.. have had one fixed (spare) and will get a new one from paddocks 89+vat (anyone know of a better price). may try and fix the other, if not you're welcome to it Chris cheers for all the info guys.. Quote Link to comment Share on other sites More sharing options...
