neilc Posted February 25, 2019 Share Posted February 25, 2019 I have recently purchased a new indicator stalk due to lights not working ( shouldn't have bothered because turns out it was a loose spade on back of switch ) since putting it in the blue light comes on the dash when I put headlights on , ( it didn't before ), it gets stronger on flash or full beam but is always on , this is actually a bonus as it reminds me that I have lights on , should this be on at all times ? Even if it shouldn't I'm quite happy it does Quote Link to comment Share on other sites More sharing options...
bushwhacker Posted February 25, 2019 Share Posted February 25, 2019 They do not stay on in 200/300 Def or 200/300 Dis. It's to alert you that you are on main beam. You may have a bad earth or live rubbing on something go to the area you have been working as a start point. Hope this helps. Good luck. Quote Link to comment Share on other sites More sharing options...
neilc Posted February 25, 2019 Author Share Posted February 25, 2019 Thanks , I'll have a look Quote Link to comment Share on other sites More sharing options...
neilc Posted February 26, 2019 Author Share Posted February 26, 2019 Ive rectified this thanks . the indicator arm wasn't fully springing back to the original position after flasing beams , I really need to investigate fully before posting! Thanks Quote Link to comment Share on other sites More sharing options...
Gazzar Posted February 26, 2019 Share Posted February 26, 2019 No, sometimes it's good to talk thing over with like minded people. Quote Link to comment Share on other sites More sharing options...
