Slick74 Posted February 25, 2019 Share Posted February 25, 2019 (edited) Hi I've got a series 2a which someone has started restoring. It's got a 2.25 diesel engine in with the 2a gearbox. I cannot get the clutch to disengage, the release bearing mechanism is about an inch off the clutch cover so everything bottoms out before the bearing touches the cover. I've removed the clutch cover which was 9.5 inch and fitted a 9 inch cover and plate but it's still the same. Any ideas? Cannot get photos of clutches to upload. 9.5 inch was finger type cover and 9 inch coil spring type cover Thanks Paul Edited February 25, 2019 by Slick74 Photos wouldn't upload initially Quote Link to comment Share on other sites More sharing options...
2a-Egg Posted February 25, 2019 Share Posted February 25, 2019 Check the flexi hose that goes between the cylinders. My clutch wouldn't return correctly, it would take 10 seconds or more, the flexi pipe had corroded and fallen apart inside itself your leg has the strength to force the fluid through but clutch doesn't on way back up Quote Link to comment Share on other sites More sharing options...
Slick74 Posted February 26, 2019 Author Share Posted February 26, 2019 Hi thanks, it's all new pipe work and cylinders. I think it's either the wrong clutch or release bearing mechanism, for some reason the release bearing isn't sitting near the clutch cover Quote Link to comment Share on other sites More sharing options...
steve b Posted February 26, 2019 Share Posted February 26, 2019 The diaphragm cover is series 3 in your lower pic , the 2/2A version of this type has a steel spacer ring fitted to the centre of the fingers . The 3 fingered cover using coil springs for grip pressure should be a different height from the pressure face to the release side of the 3 fingers compared to the diaphragm spring release side cheers Steve b Quote Link to comment Share on other sites More sharing options...
Slick74 Posted February 26, 2019 Author Share Posted February 26, 2019 Thanks Steve, I take it I may need a diaphragm type with spacer then? As currently with the top one fitted there's around an inch gap so release bearing isn't sitting close to the cover, or should the top one work also? I can't see any issues with the slave cylinder or crossbar that moves the release bearing. Quote Link to comment Share on other sites More sharing options...
David Sparkes Posted February 26, 2019 Share Posted February 26, 2019 Pictures, apart from the first, taken from the Technical Library section of the Series 2 Club. Paddocks S2A clutch plate incl spacer. 2A clutch release, inside bellhousing. Clutch slave cylinder mounting showing space for 'possibly' missing spacer. Regards Quote Link to comment Share on other sites More sharing options...
steve b Posted February 26, 2019 Share Posted February 26, 2019 The 3 finger style is normally Series 2/2A , but the only way to check both is to bolt them to the flywheel with the centre plate and measure the finger/diaphragm heights relative to the flywheel housing . The S2 should be higher , from memory it's about 1/2" . Are you sure the two cross pins in the release shaft assy. are good ? they do hide in the rubber boot , finally , is the push-rod on the m/c set with minimal clearance (pedal fully up )? cheers Steve b Quote Link to comment Share on other sites More sharing options...
Slick74 Posted February 26, 2019 Author Share Posted February 26, 2019 Thanks all Initially I couldn't get clutch pedal to work, found out the master cylinder was piped up wrong way round. Sorted that then found that release bearing wasn't moving, removed engine and found the pins missing in the cross shaft, fitted them and refitted engine. Then clutch wouldn't disengage, removed engine again and removed the bottom clutch and fitted the top but still doesn't work. I don't recall seeing a spacer on the slave cylinder, I'll take a look. I'll also check m/c settings but the release bearing is virtually fully out before it touches the cover plate. Quote Link to comment Share on other sites More sharing options...
steve b Posted February 26, 2019 Share Posted February 26, 2019 What is the part no for the 3 finger cover you fitted ? The spacer isn't a standard part I think , probably an adaption to fit a S3 slave maybe ? 1 hour ago, steve b said: the only way to check both is to bolt them to the flywheel with the centre plate and measure the finger/diaphragm heights relative to the flywheel housing . The S2 should be higher , from memory it's about 1/2" I have my doubts about the fitted finger height , it's not unheard of for old parts to be patterned to later specs. Steve Quote Link to comment Share on other sites More sharing options...
Slick74 Posted February 26, 2019 Author Share Posted February 26, 2019 It was a second hand cover a friend gave me as he thought that's what should be fitted, I didn't realise there were three types of covers or I could of measured the depth before refitting engine. I take it that there is nothing between the cover and the clutch release? My box is same as the picture David posted above in bellhousing rather than the usual clutch release bearing. Quote Link to comment Share on other sites More sharing options...
steve b Posted February 26, 2019 Share Posted February 26, 2019 It does sound like the three finger coil spring cover could be an early S3 . Pop the engine out and measure the two , everything looks to be in order from what you have said, some pic's of the LandRover would be nice , we do love a Series cheers Steve Quote Link to comment Share on other sites More sharing options...
Slick74 Posted February 27, 2019 Author Share Posted February 27, 2019 Hi Steve That's the 2a on the lifts and a 3 under it. Bought the 3 and fitted a new chassis to it, then came across the 2a and thought that would be an easy one to finish! I'll pull the engine back out again and measure the clutch heights. Cheers Paul Quote Link to comment Share on other sites More sharing options...
