henk Posted February 27, 2019 Share Posted February 27, 2019 Making a complete new dashboard for my 110 but I have troubles removing the gauges from the display. Do I need to turn them? And what about the warning light panel, is it screwed or ... ?. Quote Link to comment Share on other sites More sharing options...
Lightning Posted February 27, 2019 Share Posted February 27, 2019 Remove the dash panel with the speedometer and other gauges (four screws and it’s off) They are are held in by a large plastic locking ring that you unscrew. Quote Link to comment Share on other sites More sharing options...
dailysleaze Posted February 27, 2019 Share Posted February 27, 2019 2 hours ago, henk said: And what about the warning light panel, is it screwed or ... ?. Yes it unscrews Quote Link to comment Share on other sites More sharing options...
henk Posted February 27, 2019 Author Share Posted February 27, 2019 So the screw is the white waved ring covering the gauges? Same for the speedo? 1 Quote Link to comment Share on other sites More sharing options...
landroversforever Posted February 27, 2019 Share Posted February 27, 2019 Speedo is the same. The screw on collar on the back comes off. Warning light panel is screwed on from behind from memory..... might be clipped Quote Link to comment Share on other sites More sharing options...
Maverik Posted February 27, 2019 Share Posted February 27, 2019 The big white things are the collars. Quote Link to comment Share on other sites More sharing options...
western Posted February 27, 2019 Share Posted February 27, 2019 warning light panel unscrews from the rear, as can be seen in the photo on Retroanaconda's page, 12th photo from top of page here http://www.retroanaconda.com/landrover/2009/10/installing-defender-td5-gauges-into-a-200tdi300tdi/ gauge collar as on this gauge Quote Link to comment Share on other sites More sharing options...
henk Posted February 28, 2019 Author Share Posted February 28, 2019 Thanks for the tips: it worked fine but they were a bit stuck Quote Link to comment Share on other sites More sharing options...
