airnig Posted February 27, 2019 Share Posted February 27, 2019 Hi All My (usually trusty) 2001 TD5 110 has started leaking PAS fluid from the pump so a new one needed. 2 questions then - can a TD5 disco 2 pump (qvb101240) be used instead of the qvb101350 as they seem to be the same externally ? Can't find spec sheets anywhere on either choice. Secondly, I've just removed the ZF reservoir to clean the filter and err there doesn't seem to be one !! Its the black qfx000030 (PA66GF25) reservoir but inside there seems to be a solid white disk at the base covering only about 1/2 of the internal diameter and the exit pipe on the edge is not filtered in any way. Where then is the filter (or isn't there one on the system ?) Any ideas much appreciated. Thanks Nigel Quote Link to comment Share on other sites More sharing options...
