Lightning Posted February 28, 2019 Share Posted February 28, 2019 Anything l should know? Does the actuator rod come out with the cylinder or is it attached inside. ls there a chance of it falling into the bellhousing? Quote Link to comment Share on other sites More sharing options...
western Posted February 28, 2019 Share Posted February 28, 2019 pushrod should slide out as the slave cylinder is pulled away from the gearbox & it stays clipped to the operating arm. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted February 28, 2019 Share Posted February 28, 2019 It should stay attached to the clutch release arm by the clip, however it’s not uncommon for it to come out with the cylinder requiring a massive faff to get it back in - or in extreme cases splitting the engine/box to do so. When you remove the cylinder do so very carefully, and as soon as possible get a pair of long-nose pliers in to hold the rod in place while you extract it fully. Quote Link to comment Share on other sites More sharing options...
Lightning Posted February 28, 2019 Author Share Posted February 28, 2019 Thank you both for the advice. I will get on to it at the weekend. Quote Link to comment Share on other sites More sharing options...
