td5defender Posted March 3, 2019 Share Posted March 3, 2019 Hi All I have just changed the oil in the R380 gearbox and I'm embarrassed to say it was left too long (about 55 KM/34 Miles). But I need to be honest, and someone might learn from my mistakes. And the oil had emulsified into a pale smelly liquid after failing to replace oil after some river crossings about 30KM ago). I know not good... I've given myself a good telling off! Anyway, to make matters worst there were brass filings in the oil. See attached photo. I would like to say that was all of it, but it was only a small part of the filings I got out of the gearbox. I expect this emulfisfied oil has acted as a cutting agent rather than a lubricant? I'm very keen to hear everyone's opinion on whether this vehicle should be driven at all, or if I can carry on for the time being and reassess in XX miles/kms? (Yes fresh oil in there now!) Thank you! Quote Link to comment Share on other sites More sharing options...
Eightpot Posted March 3, 2019 Share Posted March 3, 2019 (edited) Change the oil with cheap ATF, drive it for a couple of days to flush it, if it's working ok, changing gear allright and not making a racket then drain again and refill with mtf/redline or whatever your choice is. It will probably be fine. (Just read again and noted you already put fresh oil in - drain a sample out and see how it looks now, if it's still got filings change again, otherwise if its clear you might be ok) Edited March 3, 2019 by Eightpot Quote Link to comment Share on other sites More sharing options...
western Posted March 3, 2019 Share Posted March 3, 2019 could be from the slector forks, ask Ashcrofts they should be able to tell what parts are brass/bronze inside the box. Quote Link to comment Share on other sites More sharing options...
td5defender Posted March 3, 2019 Author Share Posted March 3, 2019 Thanks eightpot and western for your comments/advice. Very much appreciated. It was driving OK prior to the oil change. no unusual noises etc. Very occasionally it didn't want to get into gear - I forget which one as it happened so rarely. I'll check an oil sample and find out what parts could be wearing. Thanks again 👍 1 Quote Link to comment Share on other sites More sharing options...
