Best engine
neil110
It's not that at all - EDC (as I understand it) is not firing injectors, it's just adjusting the pump parameters by varying a couple of actuators and possibly reading a couple of sensors, which is far simpler than what MS has to do.
However, common-rail direct-injection diesels with no mechanical injection pump have a far harder job to do than petrol injection - the injectors are dealing with huge pressures so take a more complex set of electronics to control them, the timing of the injection event is critical (much more like controlling spark than fuel) but they have to start and stop injection at exactly the right time and often fire several injections per combustion event with very tight timing. It makes petrol fuel + spark look very easy by comparison.
None of it's insurmountable, it just needs someone willing to spend the time & money and sacrifice a few engines to the R&D process :ph34r:
  • Like 1
As far as I know on the Merc ones, it controls the rack position via the throttle position, and limits that movement relative to boost pressure so it's not rolling coal.
"That's probably what I'm going to be running. Especially as it will talk to my transmission controller too."
Please tell me more about setup and intended purpose!
Which TCU?
T
Edited by Tobias
Which TCU?
T
I'm using Ole's controller from Ofgear.dk.
It's all in my build thread in my signature. I'm rebuilding my 90 (slowly) with a Mercedes OM606, 722.6 5 speed auto from an ML, coupled up to an LT230 with my own billet adaptor.
