HoSS Posted March 9, 2019 Share Posted March 9, 2019 For anyone thats interested (nothing to do with me) http://custom4x4parts.com/product/tornado-portal-kit-land-rover/ (not cheap) Quote Link to comment Share on other sites More sharing options...
Arjan Posted March 9, 2019 Share Posted March 9, 2019 Serious money for some metal bit... but € 11.250 Hmm.... Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted March 9, 2019 Share Posted March 9, 2019 They seem to have an awful lot of very nice looking (read expensive) stuff. Quote Link to comment Share on other sites More sharing options...
Snagger Posted March 10, 2019 Share Posted March 10, 2019 Using just two gears in the portal units is going to reverse the drive. They include new C&P gears with reverse helix, so that tallies up, and I can see how you can invert a Rover diff (after changing the pan), but will this work in a Salisbury axle? Genuine question, not rhetorical - i don't know if the diff housing will allow for the carrier to be fitted the opposite way around, but I have doubts. Their standard 5:1 total ratio sounds reasonable enough since oversize tyres are almost certain to be fitted. I still think they ought to give a range of diff ratio options, though, perhaps with a recommended ratio to tyre size table. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted March 10, 2019 Share Posted March 10, 2019 The details state on a 110, you need to swap to non-salisbury axle. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted March 10, 2019 Share Posted March 10, 2019 You must flip the diffs. This would require redoing the location of the studs, cutting new ring gear slots and welding on a new pan. They don't do a Salisbury version. Overall it look very underbuilt. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted March 10, 2019 Share Posted March 10, 2019 They gon break. Quote Link to comment Share on other sites More sharing options...
RedLineMike Posted March 11, 2019 Share Posted March 11, 2019 18 hours ago, FridgeFreezer said: They gon break. i think you mean they gonna escape right of the end of the axle casing 🤣🤣🤣🤣 Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted March 11, 2019 Share Posted March 11, 2019 Oh there's far too many factors to predict what's going to die first - I'm concerned they claim they have used aluminium in them, I can't see where you'd do that to any useful effect. Quote Link to comment Share on other sites More sharing options...
Daan Posted March 11, 2019 Share Posted March 11, 2019 To be fair to them, that is pretty much how I would be attempting it. The rear axle looks pretty ok to me from the picture, perhaps with a sleeved casing, even the alu portal should be ok if they did it machined from solid out of aluminium 7075 T6. Also, the rover diff will be plenty with a 1:2 reduction upstream, so a Salisbury axle is pretty much pointless. but I want to see the front: the closed knuckle is not really designed to take these loads, and the Volvo axle has an open knuckle with the bearings about a foot apart. So the question is are they using the standard knuckle or have they redesigned this into something stronger? It's easy to criticize, but there comes a point were we can't find any more Volvo axles and then how we move forward? Daan Quote Link to comment Share on other sites More sharing options...
daveturnbull Posted March 11, 2019 Share Posted March 11, 2019 On 3/10/2019 at 2:22 PM, Red90 said: You must flip the diffs. This would require redoing the location of the studs, cutting new ring gear slots and welding on a new pan None of that sounds very bolt-on to me.... Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted March 11, 2019 Share Posted March 11, 2019 34 minutes ago, Daan said: It's easy to criticize, but there comes a point were we can't find any more Volvo axles and then how we move forward? True, but those guys sell Volvo parts (and have pictures of racers with Volvo axles on their site) so I'd hope they'd have looked at the engineering that's gone into them and the potential failure modes - a replacement axle housing is perhaps one of the easier things they could manufacture and one of the obvious weak points. I don't see that making any part of that housing out of aluminium is a good idea, the Volvo castings are pretty robust (straight-cut gears and Swedish metallurgy help), by contrast Unimog ones can and do grenade themselves (helical gears) and I don't think anyone's accusing them of being under-built or slapdash in their engineering As you say, the front axle would be most interesting as I can't see LR swivels being in their happy place with 37's and an extra 100mm leverage. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted March 11, 2019 Share Posted March 11, 2019 They don't say anywhere that they are bolt-on, indeed you just need to look at the end of the axle tube to realise something needs welding the tube after cutting off the old flange. Makes me worry even more about Ross's axles spacer ideas. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted March 11, 2019 Share Posted March 11, 2019 (edited) 4 minutes ago, Bowie69 said: They don't say anywhere that they are bolt-on... Quote Bolt on portals for Land Rover done! http://custom4x4parts.com/product/tornado-portal-kit-land-rover/?fbclid=IwAR0iggs3vVlUv7y-yZI0DMf6lJQgDQ1ka80osQj_kWOLzunNFf7SrKnNhT0 Quote That is why we are now offering a portal kit that is completely bolt on. Edited March 11, 2019 by Red90 Quote Link to comment Share on other sites More sharing options...
lo-fi Posted March 11, 2019 Share Posted March 11, 2019 I'd hope they've got an ali sandwich going on, with steel plates that attach to the axle and stubs and an ali housing in between creating the space the gears run in, held in compression by high tensile bolts. If that is the case, I'd say that's an acceptable use of ali and a very easy method of manufacture. If that's not the case and the side plates are made of alioooominumanum, then I'm in the "something gon' break" camp. The "bolt on" claim does seem disingenuous with the casing needing modification to fit a flipped diff. I can't see how you'd get around that. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted March 11, 2019 Share Posted March 11, 2019 There is no way in hell those are strong enough. Without bracing the stock axle tube will bend. The portal box is way too light for the loads. No pictures of the front.... No details on the design or component size. Anyone sending them 10000 Euros needs to come and see some nice land I have for sale. 1 Quote Link to comment Share on other sites More sharing options...
Ozzy50 Posted March 14, 2019 Share Posted March 14, 2019 They dont look a patch on the Tibus portals that’s for sure and most definitely are NOT “bolt on “ 1 Quote Link to comment Share on other sites More sharing options...
