bushwhacker Posted March 19, 2019 Share Posted March 19, 2019 The above has cropped up with my 1995 90 just as I am on the push for an mot but I can't find the cause of the fault. New indicator stalk fitted, relay swopped and hazard switch changed over with my 110 parts still fasty fast but ok on the 110. I have done the checks from the Tech forum everything seems ok. I do not know where to go next. Any help would be appreciated guys. Quote Link to comment Share on other sites More sharing options...
crwoody Posted March 19, 2019 Share Posted March 19, 2019 The indicator relay is designed to flash quickly in response to insufficient current being drawn on the circuit, usually caused by a failed bulb, if you're sure the bulbs are all OK I'd check on the earth returns from the indicator lamps, particularly the rear ones, it could be they're getting a return via the tail lamp filaments which wouldn't allow enough current to operate the relay properly. 1 Quote Link to comment Share on other sites More sharing options...
bushwhacker Posted March 19, 2019 Author Share Posted March 19, 2019 Thanks All bulbs are flashing I have changed them and the fuses. I have put all new lights and sockets on and rewired the rear wires that cross from offside to nearside as they were blackened. I removed a black wire as I hoped to earth through the chassis what you have explained makes a lot of sense as to my problem. I'll be putting a new earth in tomorrow where would be the best place to bring it from the one I remove was not connected to any thing at the front. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted March 19, 2019 Share Posted March 19, 2019 Led bulbs? Quote Link to comment Share on other sites More sharing options...
western Posted March 19, 2019 Share Posted March 19, 2019 each set of rear lights should be earted to the body behind the corner cover panels each set of front lights should be earthed to the inner wing forward vertical edge behind the lights. make sure the bulbs are correct for each light & properly seated in their holders, led bulbs in normal lights are not legal, only full led lights. Quote Link to comment Share on other sites More sharing options...
bushwhacker Posted March 20, 2019 Author Share Posted March 20, 2019 Thanks. No LEDs, I hope to get a look at the earths later today. Quote Link to comment Share on other sites More sharing options...
bushwhacker Posted March 20, 2019 Author Share Posted March 20, 2019 Got it sorted 4 new earths 1 for each indicator of the body this time and back to normal flashy flash. Relief, now just need to keep it like that and see if I can get an earlier mot than 16th April. Big thanks for the help guys.👌 One to remember for sure. 👍 1 Quote Link to comment Share on other sites More sharing options...
western Posted March 20, 2019 Share Posted March 20, 2019 that's a good result, best wishes for MOT Quote Link to comment Share on other sites More sharing options...
