John111 Posted March 23, 2019 Share Posted March 23, 2019 I have a whining gear box in my defender took front prop off to check not axle, only to find I now have no drive from rear prop only front Quote Link to comment Share on other sites More sharing options...
Lightning Posted March 23, 2019 Share Posted March 23, 2019 If you remove the front prop shaft, you will get no drive to the rear one As drive will all be diverted to the output with least resistance Quote Link to comment Share on other sites More sharing options...
western Posted March 23, 2019 Share Posted March 23, 2019 Engage the centre difflock with one prop removed then it should drive, without centre diff locked, the output will go to the disconnected drive flange on transfer box. Quote Link to comment Share on other sites More sharing options...
