bearing numbers Warn m8000 winch
hurbie
hello all ,
does anybody know what the numbers are for the 2 bearings inside a Warn M8000 winch , i need the bearing on the rear of the motor (behind the brushholder) and the bearing in the motor mounting plate next to the drum.
also needed are 2 gaskets for the gearbox , are these only avelable from Warn ?
greetings gerben
ok , had a bit of a clean , and the bearing on the shaft side of the motor is a 6203DL , so i can find that local . gasket is Warn 13848 so that is solved .
now i only need the number for the bearing inside the motor , located under the brushholder.
